I'm totally lost. I have a mini dvd-r disc from a digital camcorder. Its from a wedding and the person that recorded it has chapters on the disc...
Basically, what i'm looking to do is take the disc and be able to edit it and burn to a DVD disc to play on a dvd player for the TV. I'm not a total noob but when it comes to this mini dvd-r discs... i have no idea how to edit and burn them to a normal size DvD.
I thank anyone in advance who can offer help.
I second the use of MPEGVCR. With the ability to try before you buy, you can't go wrong. I do want to tell you that while editing is easy with this software, for best results you should mark beginning and ending points on video you want to keep, save those one at a time to a clipboard, and then join them together into a new file. If instead you try to remove the video you don't want from a clip and keep the rest, the results are sometimes less than optimal. Sound sync problems can result from this method.
The onscreen documentation that comes with MPEGVCR is very good and you will barely have to read any of it to get going with the program. Just a few short minutes of reading, or maybe less, to figure out how to mark starting and ending points, save to a clipboard, and then put back together and you'll be good to go. The program is very intuitive and easy to learn to use.
VideoReDo is a similar product that you can try before you buy. You should use a similar method with it of marking starting and ending points of what you want to keep and joining those into a new file for best results. -
TDA will open it right up - and allow editing.
If you didn't want to change anything - rip in iso mode with decryptor and burn it to DVD-R;/ l ,[____], Its a Jeep thing,
l---L---o||||||o- you wouldn't understand.
(.)_) (.)_)-----)_) "Only In A Jeep"
How to Edit Out Content on Commercial Blu Ray Disc and Burn to a New BD-R?
By nagysaudio in forum Blu-ray RippingReplies: 0Last Post: 28th Dec 2010, 19:50 -
Help needed for getting videos from mini dvd disc
By jamesf121 in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 5Last Post: 8th Jun 2010, 19:05 -
How to edit Sony m2ts files to burn to blu ray disc.
By tchambers in forum Authoring (Blu-ray)Replies: 23Last Post: 11th Nov 2008, 22:53 -
Put severeal AVCHD Mini-Disc onto a DVD-5: How?
By gekko_video in forum Authoring (Blu-ray)Replies: 4Last Post: 14th Apr 2008, 15:35 -
Sony DVD recorder ruined my mini disc
By levl in forum DVD & Blu-ray RecordersReplies: 53Last Post: 10th May 2007, 13:27
