Hi people!
I'm intend to buy a desktop DVD recorder to record my favorites TV show (cable TV input). I prefer those recorders which store a file format that I may edit them on Adobe Premiere and have hard disk. Accept any reviews or similar stuff.
Thanks!![]()
Results 1 to 10 of 10
Lots to choose from ... I like the Panasonic DMR-EH50
http://reviews.cnet.com/video-players-and-recorders/panasonic-dmr-eh50/4505-6463_7-31310134.html
I have four of them and I'm only using two of them. They work just fine for my usage.
Smurf will tell you to get a JVC model.
Ebay wize ... here is the link for the remote control
http://cgi.ebay.com/NEW-PANASONIC-REMOTE-CONTROL-4-DMR-EH50-EUR7729KB0_W0QQitemZ190133...QQcmdZViewItem -
All DVD recorders store video in DVD-Video MPEG-2 format, interlaced. Some versions of Adobe Premiere will accept MPEG-2, some will not. Depends on what you're using.
Premiere Pro 1.5 ans 2 will load mpeg-2, however they decompress it to the timeline, so after editing you have to re-encode the entire video. If you are primarily editing out commercials then you are better off getting videoredo or womble mpeg wizard instead. They are native mpeg-2 editors and will only re-encode if necessary, which for standard trimming means only a few frames here and there.
Read my blog here.
I found the Philips DVDR3455H/78 recorder model. I'd like some advices about this one. Another question: how can I tranfer data from recorder to PC? Via USB or firewire?
And what recorder which records in decompressed format do you recommend?
"how can I tranfer data from recorder to PC? Via USB or firewire? "
You can use FW, those are very expensive recorders.
Panasonics use dvdram, just put it in your computer & edit it.
https://www.videohelp.com/dvdrecorders
Looking for advice on buying a new DVD recorder
By luvsufo in forum DVD & Blu-ray RecordersReplies: 4Last Post: 16th Feb 2011, 15:10 -
Buying DVD DL on Rima, need advice
By Thadius856 in forum MediaReplies: 1Last Post: 26th Jun 2008, 00:58 -
Need advice about buying a Dvd-R DL burner
By southrngntlmn1 in forum DVD & Blu-ray WritersReplies: 4Last Post: 23rd Apr 2008, 12:12 -
Buying advice for portable DVD players?
By lordsmurf in forum Portable VideoReplies: 0Last Post: 12th Sep 2007, 09:58 -
Can Anyone Recomend a DVD Recorder DeskTop with a Hard drive?
By scustalow in forum DVD & Blu-ray RecordersReplies: 4Last Post: 24th May 2007, 07:08
