I used VOB2MPG which is a great program, but it wont work on windows movie maker. Why not? I can only use it as an audio file, but it still doesnt even work (no sound....stupid). PLease help.
LITEON man!
WMM is a simple program. It prefers WMV or DV avi files, although XP SP2 includes a major update to it which expands it's abilities somewhat. Your profile says oyu are still on SP1, so you may not have the update. You can download the update separately here : http://www.microsoft.com/windowsxp/downloads/updates/moviemaker2.mspx - it probably requires WGA validation.
Your other choice is to convert the file to DV avi and go from there, or to use a dedicated mpeg editor instead of WMM.Read my blog here.
Awesome. I'll try the link, and I probably do need another program, which was a another one of my posts. Thanks!
LITEON man!
Windows Movie Maker Won't Open
By kerrex_2006 in forum ComputerReplies: 4Last Post: 29th Apr 2011, 03:08 -
Windows 7 DVD maker won't work
By 81artmonk in forum Software PlayingReplies: 7Last Post: 14th Aug 2010, 09:18 -
Windows Movie Maker crashes and won't puplish whole movie
By LoveMyslf in forum Video ConversionReplies: 27Last Post: 12th Dec 2009, 22:19 -
Windows Movie Maker Won't Publish Video or Play the Timeline
By kerrex_2006 in forum EditingReplies: 4Last Post: 12th Aug 2009, 04:14 -
Windows Movie Maker: AVI's sound bad, MPEGs won't play
By Canopus Smoker in forum Newbie / General discussionsReplies: 3Last Post: 26th Nov 2008, 10:54
