I have a dual core AMD 3800 system running Windows XP X64 Pro. I upgraded from Vegas 4.0 to 6.0 hoping to get better performance, but it's worse. Vegas 6.0 will work but it functions poorly. The program runs slower. It freezes a lot. I can't even preview raw video at normal speed much less any edited work. When toggling between programs like Photoshop oe even a windows folder, the computer freezes for 30 seconds or more. I've had to reinstall windows a couple of times. After running Vegas 6.0 I have to restart the computer before going online otherwise the computer freezes when changing websites.
I like the features vegas 6.0 offers but the problems are driving me nuts.
My question is, what is the optimum setup? How do I get the most from my system? I just want a fast stable system that will run programs properly. I use this computer primarily for editing video. I can adjust the system to suit the program or upgrade the program to suit the system. I don't know if there are any newer version of vegas that support a 64 bit system. These programs are expensive. I don't want to upgrade again unless I know it will work.
Any help would be appreciated. Thanks!
Flamin heck , the sites stuggling the last two days .
Anyway , you took the leap , and most that I know , have removed the 64bit os for good , not enough support , or a lack of those who actually "know what there doing in the first place" ... tech freaks I meant .
A major issue is much relies on hardware drivers , written perfectly , for 64bit hardware ... if it aint , then you pushing crap up hill all the way .
Not to forget codecs play a major break down for any tool if their not right as well ... a pain
But out of the blue might be something worth a squizz , which may be why its happening
http://extended64.com/blogs/rhoffman/archive/2005/05/20/525.aspx
As far as I know , the version 7 is the way to go ... for vista64 ... not sure as some xp64 users arent happy either , with many issues reported .
But it is rare to find two users with the exact same pc setup , down to the last nutt , with two unique problems , and knowing it is actually being caused by the particular product in question , and not contibuted by driver / codec / os fault .
The problem you appear to have , may be caused by the program not exiting from background and causing a conflict ... use task manager to kill the vegas product if its still running in the background , then try browser .
You do have an antivirus program installed ?
Avast and avg if you need one .
FAVC and Windows 7 x64
By CaptainFabulous in forum Video ConversionReplies: 16Last Post: 5th Jul 2014, 16:49 -
VobSub 2.23 and Windows xp x64 ?
By sat-jokar in forum SubtitleReplies: 2Last Post: 22nd Jan 2014, 22:01 -
.264 in sony vegas pro10 x64
By edy_smf in forum Video ConversionReplies: 18Last Post: 3rd Apr 2011, 19:44 -
Sony Vegas Pro 9.0e running under Windows 7
By mltwitz in forum Newbie / General discussionsReplies: 1Last Post: 16th Aug 2010, 15:43 -
Does anyone know if Vegas Pro 8.1 will work with windows 7?
By ingeborgdot in forum EditingReplies: 2Last Post: 11th Nov 2009, 20:30
