  1. joollyjohn jollyjohn's Avatar
    Mar 2005
    Sydney Australia
    G'day all
    Is this a good deal on LCD monitor?
    19” Chimei 946D-2ms DVI Wide Screen AU$ 239.00
    19” Proview FV926 2ms DVI WS 2xD-Sub 1xDVI AU$ 227
    Which one is better?
    I'll appreciate your answer.
    John
  2. Member Krispy Kritter's Avatar
    Jul 2003
    St Louis, MO USA
    I typically would go with whichever had the best specs and had good reviews. For normal, everyday surfing and office type use, both would likely be just fine.
    Google is your Friend
  3. joollyjohn jollyjohn's Avatar
    Mar 2005
    Sydney Australia
    Thanks mate
    John
