Results 1 to 11 of 11
    Jan 2005
    INDIA
    Dear team,
    I want several vcd to make DVD. for this i use TMPEG DVD authore.
    But I face some problem.
    most of the VCD file which i copied consist some sync error, padding error.
    I try virtualdub, vcd gear, procoder etc but fail to make a complete project.
    pleace help me total process....
    Little Baby
    Apr 2004
    Miskatonic U
    VCD video is DVD compliant. The audio is not. Don't waste time re-encoding the video.
    TDA will up-sample the audio to compliance. You can then change the delay to bring the audio back into sync.
    Read my blog here.
  3. Banned
    Freedonia
    I have had many problems trying to put VCD on DVD. There almost always is something wrong with the video. SVCD2DVDMPG (this is a freeware program I recently found out about) might be able to help you.
    Jan 2005
    INDIA
    no...no..
    I only want How I can copy dat file without error?
    small scratch od VCD will be ignored....
    Little Baby
    Jan 2005
    INDIA
    in this forum ... all are .... in knowledge....
    no sol .till not received....
    Little Baby
    Jan 2003
    India
    Use ISOBuster or UltraISO. If the VCD is scratched, occasionally, ISOBuster may seem to hang but it continues working.
    Apr 2004
    Miskatonic U
    ISOPuzzle is also worth a look as a free alternative to the above mentioned tools.
    Read my blog here.
  8. Banned
    Freedonia
    What is your problem? Is that you can't author a DVD using MPEG-1? Or is it that you can't copy the DAT files off the VCD without problems? I gave you a possible solution for authoring problems. Both mgh and guns1inger gave you a possible solution for DAT file copying problems. I'm not sure which problem you have because your post is vague, but hopefully between their suggestions and mine you will be able to fix it.
    Jan 2005
    INDIA
    yes ,problem to copy DAT file from scratch VCD.
    If the copy is successful by ISO buster or ulra ISO. but it is critical to authoer DVD as mpeg-1.
    Because TMPGEnc exit application if get any error in mpg file....
    pls help...
    Little Baby
  10. Banned
    Freedonia
    There's no cure for being stupid. diginode - I told you a way to author the DVD that doesn't involve TMPGenc. Either pay attention to what we say when we take the time to help you or go away. I'm not going to reply to any more of your messages if you are going to ignore what we do to try to help you.
    Jan 2005
    INDIA
    hey.....jman98.
    you gave wrong answer & I will accept...never...
    Be sure to resolve problem then post...
    Little Baby
