I decided to spin up the Blue-Ray burner to see how small I code encode one of these woppers. I realized that I can't find the subtitle stream in the .M2TS file.
I was able to extract the audio and I simply used a splitter and AVISynth to convert the video, but where are the chapters stored and are there any tools yet to extract them?
There doesn't seem to be much info out on this on Google yet except to use the old school method of noting on a piece of paper when the chapter points are![]()
Impossible to see the future is. The Dark Side clouds everything...
Surely someone must have run across this issue by now? They've been out for months.
Anyone? Bueller?Impossible to see the future is. The Dark Side clouds everything... -
Hi,
I don't even know what a blu ray disk looks like,
but i believe
you can export subs with xport,
and you can't export chapter info yet
gl
i love your aspect ratio guide -
I must not be drinking enough coffee..I actually meant Chapters, not subs. I've been using xPort for some troublesome blue-ray disks to extract the audio.
I just can't figure out where the chapters are. Ahh well..I'll bump this in a few weeks and see if anything floats up.Impossible to see the future is. The Dark Side clouds everything...
Mplayer image extract: my TGA is blue!
By RogerTango in forum Video ConversionReplies: 0Last Post: 30th Apr 2011, 13:11 -
Should Sony change the name to "blue-ray" instead of blu-ray
By yoda313 in forum Off topicReplies: 11Last Post: 17th Feb 2009, 13:52 -
What tools can copy blue-ray DVD?
By coody in forum Blu-ray RippingReplies: 6Last Post: 15th Jan 2009, 08:58 -
Blue ray Not so Blue ray
By PC2K1 in forum DVD & Blu-ray PlayersReplies: 25Last Post: 28th Nov 2007, 19:26 -
blue ray blue rot
By NICEBUD in forum Latest Video NewsReplies: 5Last Post: 21st Jun 2007, 12:01
