Greetings!
I'm having trouble with the latest version of GUI for DVDauthor (actually the previous version did the same thing). Every time I try to burn a DVD after setting up the menus and importing video files, it starts up and immediately crashes my computer and automatically reboots. In addition, when I use Video Redo to strip commercials and prepare MPEGs for use in GFD, it also crashes my machine. I use GFD in a very simple manner, just import videos, set up the menus, and burn using Nero. I have successfully burned over 50 DVDs in this manner.
I get no errors in the windows event viewer. Where are the logs stored for GFD, and would there be any useful information contained in them?
I have been using GFD for about a year now, and Video Redo for several years, and only recently have I started having these crash issues.
Any ideas what the problem is?
Thanks in advance.
Actually I have no idea. You may try to use the 'create batch' function to check if the error is 'inside' GfD already or after starting the underlying command line programs. If the 'create batch' runs without error, run the batch files in the order given in the mainbatch.bat file (but don't start it directly). Then report back where the problem occurs.
GUI for dvdauthor:
https://www.videohelp.com/~gfd/
Question about Video Redo
By snafubaby in forum EditingReplies: 6Last Post: 26th Feb 2012, 05:01 -
Video Redo problems
By Phaneendra Rao in forum Authoring (DVD)Replies: 6Last Post: 25th Feb 2012, 03:32 -
DVD Slideshow GUI Crash
By WC3 in forum Newbie / General discussionsReplies: 12Last Post: 25th Jun 2009, 18:15 -
AGK and Video-redo not recognizing my HDTV files...?
By OrangeTTT in forum Video ConversionReplies: 17Last Post: 10th Dec 2008, 02:34 -
Pinncle Studio 9.4.3 worked just fine, now CRASH CRASH CRASH
By maxtrack in forum Newbie / General discussionsReplies: 18Last Post: 11th Sep 2007, 01:38
