This one has me baffled. The other day my DVD drive stops writing/formatting DVD +R disks. It does however have no problems with DVD +RW disks. I have 3 other DVD drives that I substituted in my workstation and the same thing happens. So I know the drive is not a problem and neither are the disks because I've tried 3 different brands. I've use Nero and Roxio. Any suggestions? Thanks.
Gar
IMGBURN makes no difference. I often use the drive to store mp3 and other media files. The drive is a Toshiba SD-R5372 and I've used Sony and HP OEM media as well as CompUSA ond others. I'm thinking this is a Windows problem because the other DVD drives I through in are not recognizing the DVD +R disks. Very frustrating !
Clean the lenses and update the firmware to the latest version.
If this does not work try removing the burner with the help of the device manager and reboot.
Good luck.
Sony Optiarc DVD RW Drive writes but verify errors???
By bahjan in forum DVD & Blu-ray WritersReplies: 7Last Post: 6th Jan 2012, 09:33 -
WD External hard drive no longer works with my LG DVD Player
By KarlKarlson in forum DVD & Blu-ray PlayersReplies: 0Last Post: 28th Feb 2010, 13:16 -
DVD Burner sudenly read/writes at less than 1x speed
By Megahurts in forum ComputerReplies: 1Last Post: 22nd Apr 2009, 22:47 -
samsung drive no longer available
By newtie in forum DVD & Blu-ray RecordersReplies: 4Last Post: 17th May 2008, 13:42 -
NEC ND-3520A writes DVD's, which it cannot read
By Ruut in forum Newbie / General discussionsReplies: 1Last Post: 24th Sep 2007, 13:36
