  1. i have got blach hawk down in avi format, i got it encoded in to mpeg with panasonic mpeg prog. i then downloaded nero 5.5.5 so i can make a vcd
    problem number 1
    file 2 will fit on to a cd but part 1 wont, i have read that u can fit 800meg on a 80 min cd by over burning it, ok so what setting do i need to get it to be big enought???
    problem number 2
    i made a vcd with part 2 burned fine, but i cant seem to get it to play even in my pc. why is this???
    many mnay thanks in advance
    voodood
    __________________________________________________ ___________
    btw free cd drink coasters are on me!!!!
    just mail
    freedrinkcoasters@hotmail.com
  2. no answers as yet :(
    some body has got to know the answers
    more god dam disks turned into drink coasters :evil:
  3. Member spidey's Avatar
    Apr 2001
    U.S.A.
    In VCD format you can fit approx. 78 minutes of Video on 1 800 meg (or more importantly 80 minute cdr).
    Is part 1 longer than 80 minutes in duration ? If so . you'll have to either cut the mpg, or re-encode it to the proper durations.
    See in the DVD ripping section, under Sefy's Newbie guide, under ENCODING with TMPG, as to how to use the SOURCE RANGE function in TMPG.
    ~~~Spidey~~~
    "Gonna find my time in Heaven, cause I did my time in Hell........I wasn't looking too good, but I was feeling real well......" - The Man - Keef Riffards
  4. made vcd with part 1 and 2 but they wont fecking play help plz
