I've been using TMPEG DVD for my Divx to DVD encoding and have come across some divx files that i get errors when trying to add it as the source. It say "unable to open file, only audio part can be opened.". I'm really puzzled as when i play the file directly in WMV i have no problems whatsoever. Anyone out there has come across this error. Help much appreciated.
Being able to play it on a software player doesn't mean a lot as a player like VLC can play a corrupted file with missing frames and you may not notice any problems.
But drop one of the problem files into Gspot 2.70 and post a screen shot of the results here and someone may spot the problem. To post screen shots: https://forum.videohelp.com/topic271697.html -
Most likely it is the VBR encoded MP3 audio. A lot of converters either refuse to load it, choke while processing it, or produce out of sync audio at the end of the process.
This post : https://forum.videohelp.com/topic309224.html#1577383 will tell you how to prep the file so it converts correctly. Ignore the post at the bottom. This process was developed (not by me) because of programs like WinAVI. It is certainly no solution.Read my blog here.
Tmpgenc dvd author 3 will not author my m2v files????
By biged670 in forum Authoring (DVD)Replies: 1Last Post: 28th Sep 2009, 12:10 -
Tmpeg DVD Author doesn't like low quality captures?
By the wordsmith in forum Video ConversionReplies: 9Last Post: 20th Mar 2008, 07:30 -
Trouble With DVD Author. Please give me a hand.
By hellfire45 in forum Video ConversionReplies: 1Last Post: 19th Nov 2007, 01:31 -
Does TMPEG DVD author support multi VTS
By perfection in forum Authoring (DVD)Replies: 1Last Post: 31st Aug 2007, 17:19 -
why subtitles move with TMPEG DVD Author
By Konde in forum Authoring (DVD)Replies: 0Last Post: 22nd Jul 2007, 01:21
