I've been running a LR LRM-519 since January of this year. It has been a very fun unit to have around. Last month, however, it began acting up and freezing. I suspect that it was overheating and that the HD is burned out. I was wondering if anyone has had any experience in upgrading or swapping the HD in this unit. The LG tech people are no help whatsoever and are going to charge me $80 just to look at it and diagnose the problem. I would rather put the time and money in myself. Has anyone experimented with this model? Please share your story!
Thanks!
The drive itself should be easy enough to swap. But unless you hear different, get the same model/spec HDD.
Google is your Friend -
Its either follow Krispy Kritter's advise ... same size / model / spec , could be tricky in locating .
I know lg's help is about as useless as a two bob watch at the bottom of the harbour , but if you do send it in , get what they say they will do in writing first .
If they muck about , get a refund as first choice .
Need help with upgrading
By jaywestcwf in forum Capturing and VCRReplies: 2Last Post: 10th Feb 2010, 10:19 -
What needs upgrading on my p.c
By minidv2dvd in forum Newbie / General discussionsReplies: 1Last Post: 23rd Jun 2009, 15:12 -
LG LRM-519 and transferring files to computer
By bmoret in forum DVD & Blu-ray RecordersReplies: 1Last Post: 23rd Dec 2007, 22:42 -
upgrading to a DL burner
By efiste2 in forum DVD & Blu-ray WritersReplies: 43Last Post: 27th Jul 2007, 01:51 -
LG LRM-519 DVD Recorder
By DVWannaB in forum DVD & Blu-ray RecordersReplies: 5Last Post: 12th May 2007, 23:09
