    May 2007
    I have the Toshiba HD-DVD A2 1080I and considering on purchasing the A20 1080P. I have a Toshiba 47'' LCD 1080P. Will I see a difference if I buy the A20? Is it worth it since they dropped the prices?
  2. Member Krispy Kritter's Avatar
    Jul 2003
    St Louis, MO USA
    I'm sure edDV will clarify this, but, assuming your LCD accepts 1080P input, you might notice a difference. Chances are your LCD is already displaying 1080P anyway as it is downcoverting the 1080i input into the LCD native resolution and making it a progressive signal.
    Of course to test this, you could find a local store that carries both models and have them displayed on a similar TV or if you can get the new player locally, you can take it home and test it for yourself. Then if you don't like it, take it back.
    I personally wouldn't expect to see much of a difference between the two players.
    Google is your Friend
  3. Member ebenton's Avatar
    Jul 2003
    The WINDY state (Florida)
    From what I have read, 1080P is most useful on larger screens, such as 60 inches or more. I am not sure that you would notice much difference between 1080p and 1080i or even 720p on a 47" screen.
