First off, anyone have a help file on how to make buttons for SpruceUp? Also, anyone know where I couold find some pre made buttons aside from those that come with the program?
Results 1 to 11 of 11
I would also be interested in knowing how to make them, so someone please reply.
PSD buttons for Spruce UP
I have created several hundred DVD Menu backs as well as buttons sets for the menu backs in jpeg and PSD format,
I also have a tutorial for doing this and will post it on my site todayMichael Autery
www.EzDVDAdvisor.com
Learn DVD Authoring, recording, video editing
DVD Product Developers Community -
Sounds interesting but I dont think I can afford your yearly membership rate...perhaps I might consider a monthly but without previewing the quality of the content $99 seems a bit out of the question at the moment. Hopefully you will consider having more non-members content available, especially to preview what type of serives you are offering
Thanks anyhow
SD -
ok then I will post the info here to get you started if that will help
Michael Autery
Thanks, that is very much appreciated!! Just tell me where to look
I undertsand the benefits of having only yearly memberships but perhaps in the future you will consider offering a monthly sevice for those of us who spend _all_ our money on software
Here is the Spruce Up Goodies Button creation process you will have to have a copy of Adobe Photoshop 5 or 6 to be able to use it
It is the first one on the list SpruceUp Button Creation using Adobe Photoshop
http://www.ezdvdadvisor.com/public/department37.cfmMichael Autery
thanks again, printing info and installing action sets now
btw - does your site have additional pre-made templates for Ulead DVM? Also, does it have instructions on how to create them on one's own? I am tired of the little amount of space when entering text on some of the templates, narrows my choices down to 2 or 3 in many cases
After you download the zip file, unzip it and you will have 3 files
a Word doc
a PDF file ( instructions)
and a ATN (Adobe Photoshop Action File) you will need to install the action file in Adobe Photoshop 6 Settings folder then follow the instrctions.
here are the steps to do that
__________________________________________________ _____-
The default location of the Adobe Photoshop 6 Settings folder varies by operating system. Use your operating system's Find command to locate this folder.
To save a set of actions:
1 Select a set.
2 Choose Save Actions from the Actions palette menu.
3 Type a name for the set, choose a location, and click Save. If you save a set of actions in the Photoshop Presets folder, the set will appear at the bottom of the Actions palette menu for easy loading.
Press Ctrl+Alt (Windows) or Command+Option (Mac OS) when you choose the Save Actions command to save the actions in a text file. You can use this file to review or print the contents of an action. However, you can't reload the text file back into Photoshop.
To load a set of actions:
1 Choose Load Actions from the Actions palette menu.
2 Locate and select the action set file. (In Windows, Photoshop action set files have the extension .atn.)
3 Click Load.
To load a preset action set:
Select an action set from the bottom section of the Actions palette menu. The name of the set indicates the type of actions it contains (for example, Buttons contains actions for creating buttons).
I will consider setting the site up for monthly membership. but in the mean time I hope this helps[/b]Michael Autery
No I don't have any pre-made any of Ulead s product yet but I will soon.
Michael Autery
Like I said, I am playing with the actions set now, looks good and very professional. I would strongly consider signing up on your site if they had a good Ulead DMF template and help section, especially if I could check it out for a month rather then being obligated for a whole year at a time
Thanks for your help with SpruceUp, default buttons have always prevented me fro using SU on a full time basis but that may ll change now :P
Where did my Google buttons go in IE
By DarrellS in forum ComputerReplies: 3Last Post: 9th Oct 2009, 18:36 -
More than 12 buttons with dvdauthor
By PeskyJ in forum Authoring (DVD)Replies: 7Last Post: 17th Dec 2008, 17:50 -
Spruce Encoders
By zerohash in forum Authoring (DVD)Replies: 1Last Post: 12th Sep 2007, 06:10 -
Spruce ACX 5100 & Maestro
By zerohash in forum Capturing and VCRReplies: 0Last Post: 12th Sep 2007, 02:59 -
Animated Buttons
By Paulodemoc in forum Authoring (DVD)Replies: 3Last Post: 27th May 2007, 16:39
