I downloaded "A Scanner Darkly" and want put it on a DVD. i can't just run it through TMPG. That would be too easy. I want it to be the best conversion possible and avisynth is allowing me to reach new levels of obsessive compulsiveness.
I want to normalize each audio channel.
I heard some operations work better when you apply them to the individual fields. I want to separate fields, and change resolution and frame rate. Then you need to put the fields back together somehow... Then I think you need to change colorspace to RGB24 for TMPG right.
What is the best avisynth script for this
Original video is (from gspot)
OpenDML (AVI v2.0)
Interleave: 1 vid frame (40 ms), preload=504
Audio frames: Aligned on interleaves
File Length Correct
0x0055(MP3, ISO) MPEG-1 Layer 3
48000Hz 128 kb/s total (2 chnls) LAME3.90.°
xvid
25 frames/sec
resolution
592 x 336
Closed Thread
Multimedia Design student getting an AAS in Springfield, Oregon. I like Gymnastics and DVD authoring. I think the two go nicely together.
You seriously want the best looking video you can on DVD ?
Read the forum rules, stop downloading crushed Xvid versions of movies, and buy the DVD.
As for most what you have posted - it simply doesn't apply to the file you have. It isn't interlaced, so you don't have fields to worry about. If you need to normalise the audio then the audio is crap to begin with.
You biggest problems are blocky artifacts, whether you can see them or not. Once you scale this up for DVD it will be very obvious what a poor quality source you have.
It is no longer worth wasting time on this type of conversion. However if you are too cheap to buy the DVD, I guess you are too cheap to buy a Divx capable player so you don't have to convert.Read my blog here.
Buy it on DVD. Read the rules.
/Mats
AVSTODVD: Avisynth script edit - colorspace conversion question...
By JRM75 in forum Video ConversionReplies: 2Last Post: 26th Jul 2010, 18:43 -
3ivx Batch Conversion Available? Possible Script?
By fitch.j in forum Newbie / General discussionsReplies: 2Last Post: 12th Jun 2009, 05:24 -
Need conversion script for my website
By mdhuma in forum Newbie / General discussionsReplies: 2Last Post: 23rd Apr 2009, 01:16 -
Video Conversion Script
By paug in forum Video Streaming DownloadingReplies: 1Last Post: 16th Oct 2008, 02:49 -
Avisynth script problem (aac to wav conversion)
By greggery in forum Video ConversionReplies: 0Last Post: 22nd Nov 2007, 11:59
