Hello everyone;
I'm new at this forum and I wish you could help me.
I recently downloaded Ulead DVD MovieFactory 6, and I was enchanted with it, given that I had similar programs, but none allowed me to burn my slideshow to a DVD [since I needed about 4.7 GB memory].
Anyway, I created the slideshow, everything went great, got to the part of actually burning the slideshow to a 4.7 GB DVD, however, I noticed that even though I had already loaded the DVD, the 'Disc Type' option said -Empty-, I thought that was weird, so instead I loaded a normal CD, and the Disc Type changed to Cd-R. No problem with that.
Pretty weird for me. I dont know I'm guessing my computer or the program isn't recognizing the DVD. And I don't know what to do.
Please help me! Anything you have to say is very valuable.
Thanks in advance,
Diane
Results 1 to 9 of 9
Is this the wrong forum or something?
Someone please help me. =/ -
No , but there are many forums .
Anyway , I cant tell you what it may have been the cause as I do not use that particular product from ulead , but some clue's .
A: The disk showed "empty"
Well that could have been "its ready" or "I dont like that disc , get it out"
B: Yes , when cdr is inserted , thats what it dose change to anyway , not a problem .
The real issue may have been caused by :
1: Bad quality media ... verbatim or ty's will cause less problems .
2: Disc ok , but project too large for intended media inserted into drive ... a gotcha .
Best method is not to burn directly any project directly to dvd .
Output to a folder on your hard drive , then when its completed , check how large the folder is , if larger than intended media , you may beable to knock it down a tad using dvdshrink , or revise project settings such as max video bitrate .
There's no major issue with full d1 source at a video bitrate of 3800 ... if there is , its hardly noticable anyway .
Then burn the output using imgburn instead of the uleads internal media burning setup .
Now having said all that , I should have asked .
Are you sure you have a dvd burner ???
Thats popped up a few times before here in the forum , where op's (you are op for this post) , are not entirely sure as to what equipment they have installed in the pc , and miss this fact .
Go into control panel , system , hardware tab , device manager > dvd/cdrom drives .
What is model of drive ? -
you can check ulead forum about this find the link below
http://phpbb.ulead.com.tw/EN/index.php -
Bjs
For once I know the project isn't in any way bigger than the intended DVD.
I was just doing a test run with only part of the slideshow with music background, menu, everything and it only was 840 MB, and my DVD was 4.7 GB!!
However, now that you mention it, I quite doubt if I have a DVD burner...
I did as you told me [
Go into control panel , system , hardware tab , device manager > dvd/cdrom drives] and this shows up:
Driver Version: 5.1.2535.0
untitled%202.bmp -
live4fun
Thanks for the link to that forum I'm going to go take it look at it now =] -
thecoalman
Does what show up?
The DVD Drive?
Well yeah, in explore, in my computer, etc. -
Hey everyone again...
Problem sort of solved...
I was using my desktop to do the slideshow and it didn't recognize the DVD.
So I went and installed the program in my laptop and now its recording fine.
It was my desktop too old >_<
Thank you for the replies!
DVD player doesn't recognize XVID files
By Theodorist in forum DVD & Blu-ray PlayersReplies: 11Last Post: 18th Jan 2010, 00:42 -
Ulead DVD MovieFactory 6 prob w/using 3.7GB mpg to make DVD
By GSP_87 in forum Authoring (DVD)Replies: 4Last Post: 6th Nov 2009, 05:05 -
NEC ND-3500AG DVD RW DL burner doesn't recognize blank DVD's
By renegade431 in forum DVD & Blu-ray WritersReplies: 38Last Post: 8th Feb 2009, 07:16 -
Suddenly, burner doesn't recognize blank DVD
By slats7 in forum ComputerReplies: 9Last Post: 13th May 2008, 12:10 -
Ulead DVD Moviefactory 5
By Flying Doctor in forum Authoring (DVD)Replies: 2Last Post: 2nd Aug 2007, 11:43
