I'm having issues with the closed caption and or subtitles playing on some dvd's.
The disc menu shows it is available, but it won't work for nothing. I have run into this issue with two series from television.
Any suggestions?
Assuming you are referring to commercial discs, then it sounds like a DVD player issue. Assuming the discs actually have subtitles and/or closed caption AND the DVD player supports closed caption, all you should need to do is activate that function. You can do that via the DVD player setup menu, which usually just changes the default on or off. You can also set the option in the DVD setup menu and you should be able to turn them on/off using the remote.
Google is your Friend
Magnavox ZV420MW8 VCR/DVD Recorder ??????????????
By JABIII in forum MediaReplies: 0Last Post: 3rd Aug 2011, 06:31 -
Confusion: Magnavox DVD/VCR recorder disc/mode
By dobe in forum DVD & Blu-ray RecordersReplies: 5Last Post: 7th Mar 2011, 02:27 -
Need a hack for Magnavox DVD recorder/VCR
By jedbu in forum DVD & Blu-ray PlayersReplies: 1Last Post: 1st Jun 2010, 04:53 -
Best VCR OR VCR/DVD COMBO for restoration
By demonwarrior in forum Newbie / General discussionsReplies: 7Last Post: 24th Aug 2007, 03:02 -
Magnavox DVD/VHS TV combo Hack Code...
By Tap_Artist in forum Newbie / General discussionsReplies: 0Last Post: 12th Jul 2007, 16:58
