hi..
the program freeze after some time.. it's not like the same time, it's random.
i have the newest version of ConvertXtoDvd.
used the program maaaany times before whitout problems.
plz help.![]()
here is a word doc with a screen shot... got some errors before it frooze:
error.doc
Aside from the fact the source has some major issues that are likely to give you a poor result, the log doesn't tell us much. If you are getting errors like this before every freeze then it could be pointing to problems with codecs (although ConvertXtoDVD decodes with it's own libraries most of the time), a problem with the latest version of ConvertXtoDVD, or problems with your source or HDD.
Things to try
1. Uninstall and reinstall ConvertXtoDVD
2. Uninstall ConvertXtoDVD and install a previous version
3. Try an alternate program, such as FAVC or DVD Flick and see if it succeeds
4. Run a scan disc and defrag of your HDDsRead my blog here.
don't think i have any codecs.. should i?
tryed to uninnstall and reinstall, dosen't work.
and i had the problem with the version before this one too, so i don't think it's something there..
umm.. i'll try another program then.. although i LOVE convrtWtoDVD, i'd hate it if i couldent use it anymore -
i tryed DVD Flick, but i must say, i don't really like it... it's works fine thouht.. so i guess there is nothing wrong with my computer?
i really like to get XonvertXtoDVD working again!
DVD Flick i don't know if i did it right, but i couldent get any meny.. were i like could choose the film i would like to play. so i must like zap me trough the firt movie to get to the last one?
Converting/Burning With ConvertXtoDVD
By Teac23 in forum Newbie / General discussionsReplies: 2Last Post: 20th Sep 2009, 22:24 -
Problems converting using ConvertXtoDVD
By nadizo in forum Video ConversionReplies: 4Last Post: 10th Jun 2008, 20:29 -
ConvertXtoDvd stops converting:( HELP!
By BlackRose in forum Newbie / General discussionsReplies: 0Last Post: 18th Jul 2007, 17:05 -
Converting multiple files with convertxtodvd
By aruwin in forum Video ConversionReplies: 6Last Post: 29th Jun 2007, 04:27 -
Problem with converting RMVBs to DVD with ConvertXtoDVD. Please help!
By Centropolis in forum Video ConversionReplies: 1Last Post: 17th May 2007, 23:23
