I have a really weird problem about an mpeg-2 file and SVCD.
I got my hands on a movie which was on a 4 CD span. I copied the SVCDs from a friends CDs and they worked fine in his DVD player.
I got hom etried them.. CD 1 was jumpy and really crappy while Cd 2-4 was excellent... .I figured the first CD must have been scratched on corrupt while trasporting it home. I thought the mpeg-2 file would play from a computer so I copied the mpeg file from CD 1 to my HD and watched it in WinDVD... did'nt work. The sound was fine but not the picture. I then tried to copy CD2-4's mpeg files to my HD and watch them in WinDVD... that worked fine.
I then asked my friend to upload h mpeg file from his first CD 1 to my computer and he did... that file does'nt even have sound and can't be burned...
What shall I do.. what can the problem be?
CD 1 is the problmem, then others are fine.
I have not tried my friend's original CD in my DVD, that's one more thign I should do but since I copied his... I guess it's the same thing on them.
Is there a way to fix corrupt mpeg-2 files?? or check them somewhow?
Please try to help I'm really stuck.
Thanx/
Lars -
Well first of all, if you think the problem is a scratch on the CD, copying it to your computer isn't going to make it any better. So I would try borrowing that friend's copy first to determine whether the problem really is data loss on your CD or if it is something else.
avidemux audio sync problem with MPEG-2 - alt. way to cut mpeg-2
By graysky in forum LinuxReplies: 8Last Post: 6th Nov 2011, 21:02 -
new Virtualdub MPEG - still a colorspace problem with MPEG-&
By sanlyn in forum EditingReplies: 6Last Post: 10th Aug 2009, 22:18 -
svcd problem crashing with SP3
By kiwi76 in forum SVCD2DVD & VOB2MPGReplies: 1Last Post: 19th May 2008, 16:38 -
Encoding VIDEO_TS to mpeg-2 SVCD
By phamtom in forum ffmpegX general discussionReplies: 6Last Post: 27th Apr 2008, 15:05 -
Will the QT MPEG-2 Playback addon help my no MPEG audio on vegas problem?
By Nuke Shower in forum Video ConversionReplies: 5Last Post: 9th Apr 2008, 16:01
