I want to change my avatar, but since this forum doesn't allow size bigger than 10kb I need to re-size my new avatar from 32kb down to 10 or less. It is really hard to do it since the avatar have 69 layers (BTW why not change rules and allow little bit bigger avatars)
Anyways I can't manage to save it using GIMP 2 as PNG format. I have to flatten layers in order to do that, but than avatar won't be animated
Results 1 to 16 of 16
moved to another forum, nobody likes me here...
This one will do for now until I figure this GIMP out.
With my IQ 130 shouldn't take long time
moved to another forum, nobody likes me here... -
Well, so I made some progress and came up with 3 layers animation
Looks like I got long way to go to get to 69 layers
Anyways this is fun
All right, not bad, although this one only have 21 layers it is a full version of the original avatar with 69 layers, good job 8)
And here is the original.
That is why I was asking to increase size of avatars.Originally Posted by guns1inger
And here is explanation:
The bottom image with 69 layers is 32kb in size and the one that I came up with 21 layers is 10kb.
If you open IE 6.0 instead of FF you will see that all of them are moving. I am not sure why FF only recognize the last one.
If avatar size would be increased to 35kb I could use original.moved to another forum, nobody likes me here... -
Here I got from GIMP Help:
A little bit more info:
AFAIK there is no such thing as animated png, there is new animated format based on png. Neither IE or Firefox have support for this.
They do however support a .gif renamed as .png .
Or even .jpg like this one. Note there is also no such thing as animated .jpg.
There is a little bit about PNG and IE:
Well the original avatar has extension *.PNG, but I have no clue how it was created. In GIMP I wasn't able to save with that extension that's is why is it as *.GIF. Also I never said anything about animated *.JPG or did I?Originally Posted by thecoalman
thanks...how did you fix that?
BTW I'll change it later when the thread is gone.moved to another forum, nobody likes me here... -
What I'm trying to say is you .png is not .png but a .gif , someone just renamed it with a .png extension.Originally Posted by fLYtRap
I have a very good gif animator and have been workin with them for a while. Ulead Gif animator if you want to give it try. -
I see, now this makes sense to me since I wasn't able to save it with PNG extension.
That Ulead looks interesting but its not FREE, so I can't use it
It's packaged with their image editing program and hasn't been updated for years. You can usually pick an older version of the image editor up on sale for less than what they are selling the animator for alone online. :P
GIMP GAP Green Frames
By mixt in forum Newbie / General discussionsReplies: 9Last Post: 25th Apr 2011, 09:45 -
best review of Avatar, ever.
By deadrats in forum Off topicReplies: 0Last Post: 14th Mar 2010, 15:33 -
[SOLVED] Maintaining proportions: gimp - Cinelerra ?
By jdetwile in forum LinuxReplies: 2Last Post: 22nd Mar 2008, 10:51 -
Convert mpg to animated gif fpr avatar
By trueman in forum Video ConversionReplies: 2Last Post: 19th Aug 2007, 03:41 -
animated avatar test
By fLYtRap in forum TestReplies: 2Last Post: 19th Jul 2007, 01:57
