I am converting a 16x9 movie to .MOV to play on my 80GB Ipod using Super. I was wondering what settings I should use for aspect ration and video size. I think the Ipod only supports 320x240 or 640x480 right? If that is the case, then what should I set the aspect ratio to? I would just experiement around, but I am leaving on a trip tomorrow and do not have time to figure it out. Also, does the Ipod support 24fps or 25fps or is it only 30fps? Thanks.
I did some experimenting with just converting the first 20 seconds. I am a bit confused by the results. The input is 16x9.
Settings: 320:240 Aspect 16:9 Stretch It not selected
Results: a 320x240 video with black bars on top and bottom. No distortion of the image
Settings: 320:240 Aspect 4:3 Stretch It not selected
Results: a 240x240 video with black bars on top and bottom. The image was squashed from the sides (everything skinny)
Settings: 320:240 Aspect 16:9 Stretch It selected
Results: a 426x240 video with no black bars. The image wasn't distorted
Settings: 320:240 Aspect 4:3 Stretch It selected
Results: a 320x240 video with no black bars. The image was stretched vertically (everything was tall)
DVD > Ipod Classic > TV [Aspect Ratio]
By Will Hay in forum DVD RippingReplies: 13Last Post: 16th Jul 2012, 11:07 -
DVD > iPod Classic > TV - Aspect Ratio question
By Will Hay in forum Newbie / General discussionsReplies: 0Last Post: 18th Mar 2012, 04:05 -
Resolution & Aspect Ratio
By markf78 in forum Video ConversionReplies: 4Last Post: 11th Apr 2011, 14:17 -
Trying to change aspect ratio from 19:9 to 4:4 for mp4 iPod Docking System
By llee782 in forum MacReplies: 3Last Post: 22nd Jun 2009, 17:49 -
Tmpgenc xpress Image Resolution & aspect ratio
By sychern in forum Video ConversionReplies: 5Last Post: 24th Aug 2008, 08:25
