I know that ATI packages their AIW cards with a more up to date WDM driver while VirtualDub uses the older VFW driver model to support capturing. I also know that there is a way around this conflic which should allow you to capture using VirtualDub and AIW, specifically the fix mentioned at this link under the date 8/3/2001:
http://www.virtualdub.org/virtualdub_news_old.html
My question is this. This news article is now closing in on a year old. ATI has since released the AIW Radeon 8500DV as well as MMC 7.5. Does this workaround still work, and is it still needed? Is there anyone out there using the new 8500DV and VirtualDub? Also this workaround was for Win2K, does anyone know if it would work in XP? I'm seriously thinking of buying the 8500DV card, but I would like to continue to use VirtualDub if I can, I don't particularly like MMC.
Results 1 to 1 of 1
Guest
Virtualdub comand line crashes, but virtualdub works.
By zzyzx2 in forum Video ConversionReplies: 0Last Post: 28th Jul 2010, 14:26 -
no sound with radeon 5770 over hdmi
By lordhutt in forum ComputerReplies: 0Last Post: 20th Nov 2009, 16:14 -
ati 8500dv resource problems
By jwdove in forum Capturing and VCRReplies: 1Last Post: 27th Sep 2009, 13:48 -
problem with divx with newer virtualdub and virtualdub mod
By goingape in forum Newbie / General discussionsReplies: 9Last Post: 26th Mar 2008, 18:08 -
Monitor Image Shrinks When Using Radeon 8500DV Video Outputs
By TwoTonCarmine in forum Capturing and VCRReplies: 3Last Post: 27th Jan 2008, 16:03
