Hello, I need some help in this matter.
I have a JVC Everio G video camera. The files it creates are called .mod files which are unreadable to the PC. But an easy program I got converts them to MPEG-2 format.
But the files turn out rather large. 'My plan' is to somehow make them smaller, and as far as I can figure out (correct me if Im wrong), making them into DivX/XviD is the easiest and best solution.
But some programs like VirtualDub cant read the MPEG-2 files. So Im having trouble converting them. And this is where I need some help, not sure what I need to do. Or what program to use.
So please help, I followed some guides here. But none seem to suit my case. I may be wrong.
But a little start help would be very nice, thank you.
Hi-
You can use AutoGK to make them smaller, using either the XviD or DivX codecs. Just open the MPEG, choose a final file size and let it go to work. You don't really need a guide, but there are several on this site, as well as an included tutorial:
http://www.autogk.me.uk/modules.php?name=TutorialEN -
Virtualdubmod and virtualdubmpeg-2 will open them, if you need access to virtualdub filters.
Read my blog here.
thank you both, experimenting with the programs now. so far they work great.
so thank you. -
You could encode the mpeg-2 files to variable bitrate mpeg-2, that way you can still play them on a DVD player and achieve almost the same small file sizes as DivX.
making mkv smaller
By jetli68 in forum Authoring (Blu-ray)Replies: 2Last Post: 21st Sep 2011, 11:31 -
Making a 1 gig HD wmv file to smaller portions
By OzzyWeb in forum Video ConversionReplies: 5Last Post: 28th Mar 2010, 11:10 -
re encoding MKV files with subs to smaller file sizes with min qual. loss
By malakov08 in forum MacReplies: 1Last Post: 4th Apr 2009, 02:06 -
making an avi file smaller to burn
By enigmatic620 in forum Newbie / General discussionsReplies: 2Last Post: 13th Feb 2009, 08:29 -
Smaller MPEG-2 Files?
By DigitalSounds in forum Video ConversionReplies: 12Last Post: 30th Oct 2007, 03:55
