I have a HD JVC hardrive camcorder top of the line. The only problem is I use video clips and put them on powerpoint presentations in MPEG2 format and it is in widescreen 16:9. I can put it in 4:3 but i get the black bars and i don't want that. I can also put it in niether 16:9 and 4:3 but i get black bars on the sides. Is there any way i can convert a 16:9 into fullscreen with out bars on either sides and without it being distorted? and if i can, what is the software i need to use. PLEASE HELP!!
	and yes i did a search but everything was being converted to a TV i need to convert in my computer
	almost any encoder(CCE, tmpgenc, procoder, etc) can do it. select your output as 4:3 and make sure to select do NOT maintain aspect ratio. what will happen is the outer portion of the left and right side will be chopped off and only the middle will end up in the output.
 your camera should have the option to shoot in 720x480 FS in the menu.--
	I'm afraid its impossible either the footage is meant to be wide-screen 16x9 or its meant to be full screen(4x3) you either get the bars or you get the distortion or you cut off the sides a bit. eg just use the central portion of your video. Try tp google aspect ratio, there is a brill site with all this explained with diagramsIs there any way i can convert a 16:9 into fullscreen with out bars on either sides and without it being distorted?
 aspectratios-r-us.com
 toms-aspectratios.com
 wired.com/enslaved/how aspect ratios are a plot by the govt.htmCorned beef is now made to a higher standard than at any time in history.
 The electronic components of the power part adopted a lot of Rubycons.
	If you are ready to sacrifice part of image, it's easy to calculate. For an exactly 16:9 image:Originally Posted by arjunkkalra
 1. Cut off totally 1/4 (like 1/8+1/8) of horizontal size in pixels.
 2.Resize the rest to 720x480 and encode as 4:3.
 This will have correct AR on DVD. For videos wider than 16:9 (2.35:1 etc.) the numbers will differ.
  Full Screen Ripped DVD is not Displaying Full Screen on Widescreen TVBy jgciamarra in forum DVD RippingReplies: 3Last Post: 23rd Jan 2012, 18:42
  Windows Media Player 8 full screen DVD playback not full screenBy brassplyer in forum Software PlayingReplies: 1Last Post: 3rd Jan 2012, 16:43
  Blank screen when playing video on 'full screen'By RAYPEV in forum Newbie / General discussionsReplies: 6Last Post: 4th Aug 2011, 20:40
  DVD Lab Pro, help mixing full screen and wide screen.By stantheman1976 in forum Authoring (DVD)Replies: 4Last Post: 31st May 2009, 18:23
  DVD picture doesn't fill screen on new wide-screen TVBy ibzomie in forum Newbie / General discussionsReplies: 7Last Post: 16th Aug 2007, 04:37
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
