I may well be missing something here, but I'm distinctly puzzled by the absence of Avimux_GUI from the list of Megui updatable files.
I discovered this when AutoEncode insisted on calling on Avimux_GUI, and AviMux_GUI wasn't there. This was with a fresh install of MeGui 0.2.4.1043 on which autoupdate had been run. So it seems that MeGui doesn't install AviMux_GUI, doesn't autoupdate it, and yet insists on trying to use it.
I installed AviMux_GUI manually and set a path to it in Settings, but I'm getting persistent errors with it in batch mode. It seems to throw an objection to CBR, which in itself is puzzling (As a long-standing VDubMod user I was brought up always to use CBR in AVIs). The Adaptive Muxer used manually seems fine -- anyone know how I can get batch mode to use this instead of AviMux_GUI?
As a total newcomer to MeGUI I'm impressed by its ability to set up 2-pass batch encoding while accepting avs input, and it seems to do everything I need. But this last hurdle of muxing in batch mode is defeating me.
So, a few questions, if I may:
1) Why is AviMux_GUI there at all -- the Adaptive Muxer seems to work better.
2) Why, if it's there for a good reason, isn't it included in the install and the update list?
3) Why does it seem to insist on VBR audio input into AVI containers?
4) Is there some way of dropping AviMux_GUI out of the batch process and using the Adaptive Muxer instead? What would be the downside to this?
voodle
Results 1 to 1 of 1
MEGUI R!pp!n !!!!!!!!
By vickynash in forum Newbie / General discussionsReplies: 0Last Post: 11th Jun 2010, 11:29 -
MeGUI
By anirban in forum Video ConversionReplies: 4Last Post: 4th Dec 2008, 20:28 -
help using megui
By 3289275 in forum Video ConversionReplies: 2Last Post: 12th Oct 2008, 09:26 -
Changes in MeGUI
By Dschultz in forum Blu-ray RippingReplies: 3Last Post: 24th Sep 2008, 16:55 -
using megui
By cowboysroy31 in forum Newbie / General discussionsReplies: 2Last Post: 4th Jun 2007, 11:42
