    Sep 2004
    Australia
    Hi I'm trying to get more info on this portable mp4 player called walkm8
    I want to find out if it can play h264 codec and the pixel resolution size and battery life
  2. Member Krispy Kritter's Avatar
    Jul 2003
    St Louis, MO USA
    More info may be helpful. What little I can find, leads me to believe this is an Australia only model. The manufacturer website would be a good place to start.
    Google is your Friend
  3. Always Watching guns1inger's Avatar
    Apr 2004
    Miskatonic U
    It appears to be a re-badged something, so the wak-m8 name is local (and probably just for Stratfield). It appears (from what little turns up through google) that is uses AMV for video compression. It comes with it's own tool for compressing video, although SUPER should also be able to do it. I would suggest you call Stratfield and ask them for details.
    Read my blog here.
