I'm having some trouble..... I finished a 3 minute piece to put in a powerpoint presentation. Last week I did it and everything looked fine. The last two days, however, it doesn't. The image jumps a bit and the sound does too at times. Not a lot, but enough to make it frustrating (especially if it was OK before). I edited using premiere 6.5, and made a wmv. using "best quality for broadband". Should I be using a different setting?
I have everything defragged, antivirus and other stuff off, etc.
One thing to note - last week when it was working fine, I always attached the video and set it to run if you clicked on it, last two days I set it for automatic, and the image and audio jumps. I tested it several times and this always happens - odd.
In a roundabout way, is the setting I used best for powerpoint or is there a better one? I also tried mpeg-1, but it wasn't as good.
Thanks for any help!
Results 1 to 1 of 1
winxp - 3.06 -
How to make a VERY HIGH QUALITY DVD of an old Premiere6.5 -not pro-project?
By pregunto in forum Video ConversionReplies: 6Last Post: 5th May 2011, 01:32 -
powerpoint conversion to VCD
By Kratz in forum Video ConversionReplies: 2Last Post: 19th Feb 2010, 15:16 -
Powerpoint to Video Help
By annieo in forum Newbie / General discussionsReplies: 1Last Post: 2nd Aug 2009, 09:23 -
Basic questions - PowerPoint to WMV to connect with AVI files to make DVD
By epotereiko in forum Newbie / General discussionsReplies: 0Last Post: 20th Apr 2008, 13:56 -
Burn Powerpoint to DVD?
By ranchhand in forum Newbie / General discussionsReplies: 6Last Post: 5th Sep 2007, 09:33
