I have a few movies I shot with my video cam I just got and uploaded them as AVI files to my computer I now want to covert over to my DVD's so I can watch them on my large tv. I have tried Nero but keep blowing up on me for some reason when I try to import the AVI file. What other programs can I try to achive this?
Assuming it's from a DV camcorder, it would be DV-AVI format, about 13GB/hour of video. Just about any MPEG encoder should accept it. The audio is probably PCM, so you can reduce it's size considerably by converting to AC3 with a program like ffmpeggui or similar.
I use TMPGEnc for encoding, but the freeware HC or even SUPER should be able to encode it. I encode the audio separately after doing my edits, then add back in when authoring to DVD. For easy, you can use ConvertXToDVD and it will give you ready to burn DVD files. Some of the other All-in-One DVD converters may be able to do that also.
With handheld DV footage, you usually want to use a fairly high bitrate, so optimum would be about one hour of video per DVD. -
Ok, Thanks. I also have straight AVI files I would like to put on DVD's so I can view on my DVD player on the tv. What is good for this? I tried Nero, but it kept blowing up on me when I tried to add the avi file. Is nero the only thing that does this?
Thanks -
I would not suggest Nero to convert from AVI to DVD. I would recommend TMPGEnc 4 Xpress to encode your AVIs to DVD compatible MPEG-2 file. Other encodres like HC may be little faster but I am personally quite happy with all the TMPGEnc encoders.
After you get your MPEG-2 file then author it with TMPGEnc DVD author or any other authoring tool of your liking except Nero !When I was born I was so shocked that I could'nt speak for 18 months.
How to burn AVI to DVD without converting
By ss4nemis in forum Newbie / General discussionsReplies: 16Last Post: 19th Nov 2012, 21:43 -
I encoded AVI to DVD but can't burn
By simonuribe in forum ffmpegX general discussionReplies: 1Last Post: 12th Jun 2009, 16:32 -
Want to burn AVI TV Series on DVD
By koenf1 in forum Newbie / General discussionsReplies: 1Last Post: 8th May 2008, 17:36 -
Burn Software with Menu & burn xvid avi
By CynthiaBlue in forum Newbie / General discussionsReplies: 3Last Post: 4th Jul 2007, 21:46 -
burn hours of avi to dvd
By hackerzlab in forum Newbie / General discussionsReplies: 2Last Post: 1st Jun 2007, 14:46
