I am trying to figure out how to open a file I emailed to myself. I took a picture on my camera phone and emailed it to my yahoo account so that I can save it on a PC and view it in a larger format 640x480. Anyways, it worked, except all I can view is the thumbnail version of it. If I click on it to save the attachment or open the attachment it says it's a .bin file format. Although it says the image is .jpg format...
Anyways, I looked up in google/yahoo about opening .bin files and all questions/answers I saw about it were referring to .bin VIDEO files for games. This is a .jpg.
Any ideas?
	Well, MPG movies are just a lot of JPEGs strung together.  But I haven't seen that particular problem before. Unless you created it, it shouldn't be a .bin file. Do you have 'Hide extensions for known file types' unchecked in folder options? It may just be that Windows is associating it to a .bin file format. You can always change the extension. But I haven't seen that particular problem before. Unless you created it, it shouldn't be a .bin file. Do you have 'Hide extensions for known file types' unchecked in folder options? It may just be that Windows is associating it to a .bin file format. You can always change the extension.
	Have you ried renaming it with a .jpg extension?
 Did a search that brough me to this: http://www.webmasterworld.com/forum49/721.htm
 Your phone is probably appending the .bin extension to insure it gets transferred correctly.
	Ok, that worked. I thought I had tried that before, simply renaming it .jpg. But I just tried it, renaming the file as I save it and it worked. I think before maybe I saved it, then tried renaming it .jpg. I'm not sure, anyways, it worked.
 Thanks for the info!
	I just ran into a similar problem with a JPEG file I sent as an attachment with a Email. It came out the other side with a .txt extension.  Changing it back to a JPEG worked, though. Probably something I did when it sent it. Changing it back to a JPEG worked, though. Probably something I did when it sent it.
  Cover (jpg) in mp4 file???By the_partyman in forum Video ConversionReplies: 4Last Post: 10th May 2014, 12:19
  Add a jpg in a mkv file at the beginingBy flash_49 in forum EditingReplies: 5Last Post: 20th May 2010, 19:17
  Opening Or Playing a .Bin Format Video?By niteghost in forum Video ConversionReplies: 12Last Post: 6th Oct 2008, 08:42
  What do you use for jpg/gif file size optimization?By sdsumike619 in forum ComputerReplies: 10Last Post: 28th Apr 2008, 05:00
  How to insert a jpg file in the middle of an avi file?By pmolson in forum Authoring (DVD)Replies: 7Last Post: 2nd Jul 2007, 03:26
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
