I'm trying to convert my .wmv movie to an .avi using SUPER as recommended in
some of the threads I've done my research on. Reason being is that I am trying to convert
my movie so I could use AutoGK to combine the .ssa subtitles into one file.
I've started the conversion process this morning and I've been waiting all day for it to be
completed. This is what is happening...
The little green status bar that I assume gives the project completion status has already
been all the way through 2 times already and it is starting over once more.
Is this normal?
I'm kind of running on low on time and I'm quite a bit concerned if it's even accomplishing
the task that I wish to be performed.
Here are the settings it is on,
Output Container - AVI
Output Video Codec - XviD
Output Audio Codec - MP3
MEncoder selected
VIDEO
Scale Size: No Change
Bitrate: 1008
Hi Quality
48K Audio
AUDIO
Channels: 2
Bitrate: 128
how long has it been running? That green bar usually doesn't give any kind of approximation. It's just there to show that it's working, at least as far as I know. The other day I had a file in SUPER and it took around 5 hours, but it was an OGG file so it was struggling with it...
and anything else you on that same machine, surfing dling, is going to slow things down even more
What is AVI(for pocket PC) in Super?and keep aspect ratio in Super ?
By SingSing in forum Video ConversionReplies: 2Last Post: 19th Dec 2009, 22:05 -
Are these lines normal?
By Abas-Avara in forum Newbie / General discussionsReplies: 12Last Post: 18th Oct 2009, 12:41 -
SUPER - is it really super? (a behind-the-scenes look)
By BaronJT in forum Video ConversionReplies: 5Last Post: 2nd Aug 2009, 09:29 -
Normal or not?
By alintatoc in forum ComputerReplies: 4Last Post: 25th Mar 2009, 01:36 -
Normal encoding
By mrgorgeous in forum ffmpegX general discussionReplies: 4Last Post: 5th Oct 2008, 18:42
