Hi All,
I'm trying to create a DL DVD using Dvd Lab Pro 2.19. I have a .VOB file that I created with VOB merge and I just noticed that the aspect ratio is 704X480 when I tried to add this file to Dvd Lab. Dvd lab is suggesting that I put this video into a different VTS Menu. Since my other files are 720X480.
Is there anyway I can fix this .VOB file, so that it works in DVD Lab without creating a another VST Menu of a different aspect ratio?
http://www.tinkertimes.com/Photo/gspotaspectratiooff.jpg
Thanks.
Matt
I would use a separate VTS (i.e. you shouldn't mix formats/resolutions in the same VTS). You can add a BRIDGE object to link to the movie (Menu button to Bridge, then Bridge to Movie in separate VTS).
Regards,
George -
I have about 8 different video in one VTS menu, with a Main, Scene Selection and Bonus Menu. If I use the Bridge object, and setup the video into its own VTS, can I still link directly to it from my Bonus Menu I already have setup correct? This way I don't have to create a new menu system for second VTS Menu.Originally Posted by GeorgeW
Thanks.
Matt -
Yes, Menu Button to Bridge, then Bridge to Movie in separate VTS.Originally Posted by mlong30
You can do the same the other way (Movie in separate VTS to another Bridge, then that Bridge back to a specific Menu).
Regards,
George -
4:3. 5:4. 16:9 these are aspect ratios
704*480 is the pixel demensions , the display aspect ratio determines how the picture will be stretched or squezzed to fit the screen
and files with different demensions shoud be in seperate vts
How to change menu aspect ratio in DVD-Lab Pro ?
By V879 in forum Authoring (DVD)Replies: 2Last Post: 1st May 2011, 17:11 -
Ripped VOB #1 wrong aspect ratio, all others ok!
By silver007 in forum DVD RippingReplies: 8Last Post: 6th Jun 2009, 12:01 -
Some VOB's not displaying the correct aspect ratio
By Browncoat in forum Media Center PC / MediaCentersReplies: 26Last Post: 20th Mar 2009, 03:57 -
VOB Aspect Ratio
By Lt. Dang in forum Newbie / General discussionsReplies: 7Last Post: 1st Feb 2009, 19:17 -
.vob to .dv, aspect ratio problems
By Groove_Holmes in forum ffmpegX general discussionReplies: 2Last Post: 23rd May 2008, 21:34
