Hello people!! I just a quick question if you don't mind!! I installed my Pioneer DVD writer yesterday.. When i turn the computer on and looked under device manager both of my drives wasnt on there. I went in and deleted all of the IDE ATA/ATAPI Controllers that "would" delete, and restarted the computer.. And got the same result. Then I went under My Computer to try to click on the E drive becasue it had a cd in it and it said something about an I/O error. Can I have a little help please. It would be greatly appreciated.
Results 1 to 13 of 13
Could be a connection problem especially if it used to work. Are the drives properly set to Master and Slave? Try a different IDE cable. See if the drives show up in the Bios settings.
If the bios doesn't see the optical drives, Windows won't either. -
The cd-r drive that came with the computer always worked before i hooked up the pioneer. AFter i hooked up the pioneer neither of the two worked. Do both of the drives have to show up on the device manager screen to set them to master and slave? How do you check the bios to see if they will show up?
You set master and slave with jumpers on the drives. The new DVD drive should have included instructions and a new cable. Your computer or motherboard manual will include instructions for bios settings (if necessary).Originally Posted by hollywoodfussell
Ok. I finally got it acting right. But know it won't read my dvd+r
The drive you have is the RETAIL version of the PIONEER 111. Make sure you're using a 80 conductor ide cable. This a requirement of the drive otherwise it won't work correctly. The drive should be in UDMA 4 MODE. If it isn't then the cable you're using isn't a 80 conductor ide cable.
go to device manager and click on the ide ata/atapi controllers look to see if your drive is in UDMA 4 MODE. -
I dont see anything that says UDMA 4 MODE. Where do i go to get the cable and how much does it cost?Originally Posted by budz
You need to go into the control panel then go to hardware tab then to device manager then to hardware. Click on the IDE/ATA ATAPI controllers, there you'll find PRIMARY, SECONDARY channels. Find the one where your PIONEER 710 drive is on. Usually DMA 5 is the hard drive. If you see UDMA 4 MODE then your PIONEER drive is in the correct DMA mode. If you see PIO or DMA 2 mode then the ide cable you're using is not a 80 conductor ide cable. You can get a 80 conductor ide cable from any local computer store or buy one online. They're very cheap.Originally Posted by hollywoodfussell
Here's a few online store you can buy a 80 conductor ide cable:
SVC.com 99 cents for a 80 conductor ide cable!
http://www.svc.com/rc18hd2-yel.html -
I went and bought an 80 conductor cable and my dvd's aren't finalizing still.Originally Posted by budz
Yes the drive is in udma 4 mode. I put my pioneer on master and the other one in slave. And i'm using nero. I downloaded the imgburn but i got didnt know how to use it. II'm trying to put an avi file on dvd and on imgburn it doesnt allow you to do that. so what should i do?Originally Posted by budz
I believe you can use CDBurnerXP Pro to burn AVI files. Here's the download for it. It's a freeware and excellent to use for cds and dvds.
http://www.cdburnerxp.se/download.php
Pioneer DVR-530H Question (Please help)
By Corey_Futurama in forum DVD & Blu-ray RecordersReplies: 7Last Post: 10th Jul 2010, 07:28 -
Pioneer DVR 645H question
By kevinn in forum DVD & Blu-ray RecordersReplies: 1Last Post: 26th Apr 2010, 06:12 -
Pioneer DVR-531H-S Question
By mattg568 in forum DVD & Blu-ray RecordersReplies: 4Last Post: 12th Jun 2008, 04:48 -
What is the best DL media for Pioneer 1810 and DVR-710 drives ?
By MacPCConsultants in forum MediaReplies: 9Last Post: 2nd Dec 2007, 13:37 -
Q: for Disc Jockeys Pioneer DVR-111D / DVR-710
By edDV in forum DVD & Blu-ray WritersReplies: 10Last Post: 14th May 2007, 22:12
