    Jul 2005
    Canada
    I'm sure all of you know what these items mean by experience and hours of use and posts to ChrissyBoy, but as a new trial user, looking to archive to DVD, where / how do I find an explanation of each option. The videos are at a kindergarden level, and of no use in exercising the power of the program. Thanks.
  2. Member ChrissyBoy's Avatar
    Feb 2003
    Yorkshire!
    If you hover your cursor over any item in the settings window it will give you a detailed description:
    If that is not enough - just ask and I/others will expand.
    Jul 2005
    Canada
    Boy, sometimes I feel dumb! Thanks.
