Can Divx/Xvid files be placed onto DVD for play on a capable standalone machine? What software would you recommend? Will I be able to build a "DVD-like" menu with selectable audio/subs for each title? It would be nice to put a bunch of episodes, or a few movies onto one DVD for when traveling. Please note that I'd like to place them onto DVDs with these capabilities; not CDs. Is this even possible?
-The Mang
Yes, you can do this. The only software I am aware of that can make such menus is TMPGenc DVD Author with Divx authoring capability. The bigger problem you'll have is that to understand the menus, you must have a standalone DVD player that is Divx 6 certified. There aren't a lot of those players available right now.
That would be a player that is divx ULTRA certified... like the philips 5980.
divxmediabuilder does a nice job and works with pre-existing files of both stripes (xvid and divx)
And remember no single file can be over 2gb in size... which is a disappointing limitation..
possibly fat32 relatedCorned beef is now made to a higher standard than at any time in history.
Thank you gentlemen for your replies. One more question.
If I create DivX/Xvid onto DVD's with menus, subs and multiple audio tracks, will I still be able to watch them on a non-DivX Ultra Certified player? I realize I would not have a menu, but would I still be able to switch subtitles, audio tracks and possibly chapter forwards and back using the remote?
Thanks again.-The Mang
Convert AND Combine Multiple VCD DAT files to Single Divx/Xvid file
By GrayStrickland in forum Video ConversionReplies: 4Last Post: 17th Aug 2012, 13:23 -
How to create a DVD using multiple DIVX/XVID files with Menu
By Amourek in forum User guidesReplies: 2Last Post: 2nd Mar 2009, 09:57 -
want to add forced subs to divx/xvid files
By gossipninja in forum SubtitleReplies: 3Last Post: 23rd Jul 2007, 04:26 -
AVI,DivX,XviD to DVD with switchable subs using DVD2SVCD
By Baldrick in forum User guidesReplies: 18Last Post: 6th Jul 2007, 17:08 -
Problems w/selectable subs avi-DVD w/mpeg2enc
By kenzo69 in forum ffmpegX general discussionReplies: 1Last Post: 20th May 2007, 06:53
