I use TMPGEnc 2.01.30.116. I am trying to convert the movie Monsters, Inc. (filename: [mp]monstersinc.ts.avi) Now, I do not know the format of this movie, it is 159 MB's and just under an hour and a half, but I was pretty sure it's not DiVX. Anyway, for whatever reason the audio will stop converting after 32 seconds and just the video will play. I've tried almost every setting on layers 1 and 2. I've also tried Output to Wave file in the File menu- same thing. The original movie does play correctly in Media Player with no noticable glitches at that spot. I have DiVX codecs installed, and the VFAPI plug-in for TMPGEnc turned on. Any help would be greatly appreciated. I am sorry to make this so long, thanks!!
~Chainu
One last thing, it will not open in any version of Virtualdub or that dBMusic converter thing.
Try increasing the priority of Direct Show filter in TMPGEnc to 1. I think its under enviormental settings...look around for it.
Need help converting to MP4 with TMPGEnc Express
By rede96 in forum Video ConversionReplies: 0Last Post: 11th Aug 2011, 15:29 -
Converting AVI using TMPGenc = No Sound?
By CaptainChaos in forum Video ConversionReplies: 2Last Post: 16th Dec 2008, 16:12 -
Converting Video for a Blackberry using TMPGEnc
By Vachoen in forum Video ConversionReplies: 3Last Post: 9th May 2008, 15:06 -
Help converting a Xvid to DVD with TMPGEnc 4.0 XPress
By ozzhead42 in forum Newbie / General discussionsReplies: 1Last Post: 19th Dec 2007, 14:01 -
TMPGEnc Error converting asf to MPG-2
By Caned_and_Able in forum Video ConversionReplies: 7Last Post: 6th Jun 2007, 10:07
