Hi guys well my brother gave me two dvds a couple of days ago of an event they taped on video cam. However the lighting isnt too good and neither as the colours so what i want to do is the following
Take the 2dvd 5s and convert them to a single DVD 9
Remaster the colour and contrast levels and remove any blocky artifcats
Boost the sound and also add a slight echo to it
Convert the 2.1 audio track and change to 5.1
and finally put a decent main menu system to bring the whole thing together
but im not to sure how i do this all. so this where you guys come in. i need you help and advice on tools and techniques i will need to accomplish it.I can pop screen shots showing how the video currently looks like if it helps.. Anyways i leave it with you guys
If you're going to go through all that trouble you'd be better off having him send you the original files. Assuming it's from a DV-AVI cam you can get about 18 minutes or so on a single sided DVD.
well the recording was taken last year so we dont have the master tapes or any of the files so ive only got these to work with
Virtualdub has filters than do all that you are after, however it will come at a cost. DeBlocking will soften the image. Upping the brightness will most likely increase noise, which will in turn require a high bitrate when re-encoding or you risk putting back worse blocking. In creasing the audio to 5.1 will most likely mean using a higher bitrate when re-encoding, which will eat into your video bitrate allocation.
None of these are end of the world items, but things you should carefully consider.Read my blog here.
Complete Remastering of a Demo (music audio track)
By Gwar in forum AudioReplies: 6Last Post: 17th Jun 2012, 12:15 -
remastering FILM 16mm/35mm
By iigood in forum Video ConversionReplies: 8Last Post: 4th May 2010, 00:18 -
DIGITAL Remastering?
By blueprint in forum Newbie / General discussionsReplies: 3Last Post: 18th Jun 2008, 06:08
