Hello all, Would anyone know how I might slow audio down 4% to match video using Adobe Audition (version 1.5)? Say for example, when doing a Pal to Ntsc (25fps to 23.976 fps) conversion. I have looked at the user's manual and cant seem to find out how its, done, or if it can be done at all with this application. I looked at the stretch feature under, Time/pitch, by clicking on the effects tab (seemed like the most related option), but cant figure it out, I'd like to learn how with this particular app so not to have repetitive audio editors installed on my machine. I also use Audition mainly for creating individual Mono wav's and panning assignment of my audio files/streams, when preparing them to be used in SurCode DVD DTS.
FulciLives has advised me on how its done with Goldwave, (and after trying it , it worked perfectly) and I'm very appreciative to him for sharing the process, although I'd like to learn how its done in Audition.
Thanks Much
Hittz
Results 1 to 12 of 12
import your file into adobe audition 1.5.
then click effects>time/pitch>stretch.
to slow down the audio by 4%,simply change the ratio value from 100 to 104.
Your help is greatly appreciated Mike, although I haven't tried it yet, Would I actually set it to 104% or go down to 96% to slow the audio down?Originally Posted by mike20021969
If you want that pitch change when going from PAL to NTSC audio, under stretching mode you have to click on resample(preserves neither). Then set your ratio to 104.27. This will slow down you audio and make it a longer duration.
I would like preserve the sound so the pitch sounds the same as the original (prior to any editing) So would I choose, Time stretch (Preserve Pitch) ?
Yes use time stretch(preserves pitch).
But now you have to use the ratio of 95.904 instead of 104.27.....in order to slow it down and make the duration longer. -
Gotcha, I'll give it a try.
Thanks much Pinstripes23, much appreciated
to slow down audio you increase the value to to more than 100%.Originally Posted by Hittz
to speed up audio you go below 100%. -
That's only if he wants to resample(preserves nothing). But in his following posts he wants to preserve the pitch so he has to tick on "time stretch" and change the ratio to 95.904 - this will slow down the audio and make the duration longer.Originally Posted by mike20021969
I accomplished the above task by slowing the audio down 4% (ratio set to:95.904) and using the preserve pitch setting. My Pal to NTSC video plays in sync with my edited audio file fine now. I appreciate all the help you both gave me.Hello all, Would anyone know how I might slow audio down 4% to match video using Adobe Audition (version 1.5)? Say for example, when doing a Pal to Ntsc (25fps to 23.976 fps) conversion.
Mission Accomplished Thanks Pinstripes23 and Mike20021969 for the fruitful help!!!
In German it's under Effects/Zeit und tonehöhe/Drehnen. How can I have all in English because a lot of the options are in German (probably because my Windows is German). The help at adobe.com is absolutely garbage. thanks
Adobe Audition 3 Crashing at Start up
By EmpireStrikesBack198 in forum AudioReplies: 4Last Post: 27th Feb 2016, 08:27 -
Problem stretching AC3 audio with Adobe Audition 1.5
By Gwar in forum AudioReplies: 6Last Post: 21st Aug 2011, 08:15 -
Adobe Audition 3.0 imports as 32-bit
By ranosb in forum AudioReplies: 4Last Post: 29th Jun 2011, 01:35 -
Adobe Audition
By nic3 in forum AudioReplies: 1Last Post: 27th Jan 2011, 13:36 -
Adobe Audition Mixdown- Slow audio
By tharps22 in forum AudioReplies: 0Last Post: 30th Nov 2009, 01:04
