Hi
I want to dub old footage from VHS tapes to my Panasonic NV-GS320 video camera (MiniDV). The camera is equipped with a "DV" plug which the local camera shop tells me is a four-pin firewire. They claim that what I want is impossible using a cable.
I was imagining that I could use a cable with RCA plugs on the VCR end and the firewire on the other. From there, get it onto the computer to edit & make a DVD.
Can anyone help on this?
Thanks,
Mark.
I don't think it would work. The signal from the firewire is digital and your analog camera puts out analog. Incompatible. Do you have a DV/ analog input on your digital camcorder? The one on my JVC looks like a headphone jack plug. You could plug your analog into your digital this way, or, what I did recently was I purchased an Avermedia DVD EZmaker PCI capture card from Tiger Direct. It cost me 20 bucks and installs in a standard PCI slot in your computer. You plug your analog camera video into that and audio into your microhone plug or line in plug on your computer. The picture quality is on par or, I think, better than DV.
The only way you can do it is if your camcorder has analogue inputs (usually using the same connections as for analogue out), unfortunately, according to here http://www.camcorderinfo.com/content/Panasonic-PV-GS320-First-Impressions-Review/SpecsRatings.htm yours doesn't.
What you are wanting to do IS possivle if your camera supports AV/DV passthru. I have a Canon ZR700 (which does) and have copied many VHS tapes and hi8 tapes this way. It uses the SAME cable as when outputting video to a TV with a composite connection. The bonus is that this setup also acts like a TBC to help correct any tracking errors on your source. It also almost always defeats Macrovision errors that pop up when capping commercial VHS tapes.
You will need to search thru the menus to see if you can do this. I did some searching of your particular model but could not find anything specific
Problems with my VHS/8mm/MiniDV to DVD project
By compgl in forum Capturing and VCRReplies: 6Last Post: 15th Jan 2010, 09:30 -
VHS dubbing to DVD
By vegaspat in forum Newbie / General discussionsReplies: 11Last Post: 29th Mar 2009, 04:55 -
vhs to dvd dubbing
By zhavoronkova in forum DVD & Blu-ray RecordersReplies: 7Last Post: 22nd Jan 2008, 10:45 -
Transfer data code while dubbing miniDV -> DVD+R using IEEE1394/iLink
By alokeprasad in forum Authoring (DVD)Replies: 0Last Post: 24th Dec 2007, 08:25 -
VHS via MiniDV passthrough, no video but audio is fine
By TerryNG in forum Capturing and VCRReplies: 6Last Post: 21st Jul 2007, 13:50
