    Jul 2007
    I have a Dell Latitude D520 with specifications that it can burn dvds with any type of dvd ware such as DVD +/- R. I also have all the burning software such as Nero. However, when I put in Memorex DVD + R in the DVD rom drive it didn't load at all. The Nero, Divx, and even windows media displayed that there wasn't a disk in the drive at all. I really want to burn a dvd. Another weird thing was when I put a burnt dvd, specifically TDK DVD-R it played the video on the disk. I want to know what's the problem...is it the drive or the disk, because I want to burn a dvd. Please help.
    Feb 2004
    Australia
    Welcome chrang
    What model is the burner ?
    Mines the D610 with external lg unit , and internal liteon dvdrom / cd burner combo .
    Sounds like you only have the dvdrom drive , and not a dvd burner .
  3. DVD Ninja budz's Avatar
    Jan 2003
    In the shadows.....
    MEMOREX is crappy dvd media. I'd suggest you use another brand of dvd media like VERBATIM. Are you sure your laptop can burn dvd media? You mentioned putting in a disc in the dvdrom drive. I never knew a laptop can have 1 dvd burner and 1 dvdrom.
    Feb 2004
    Australia
    budz , these dell latitudes , D series can do it all .
    Duel batts (7 hour runtime on larger capacity batteries) .
    Or while on mains power , you can remove the battery and install another drive , such as burner , floppy , hard drive .
    Just getting the caddy for the left is difficult to get a hold of .
    Now where that tv out post go to ... my 7pin minidins arrived ... and I have now COLOUR output from the laptop .
    Bought 3 and got a 4th for free ... more cables than I know what to do with ... except not to trip over them .
  5. Member classfour's Avatar
    The Heartland, United States
    bjs likely has it correct: It looks like you have the combo drive - not a burner.
    ;/ l ,[____], Its a Jeep thing,
    l---L---o||||||o- you wouldn't understand.
    (.)_) (.)_)-----)_) "Only In A Jeep"
    Jul 2007
    Thanks! Is there any way to burn on this laptop then? Do I have to buy a dvd burner? If so, which kind?
  7. Member classfour's Avatar
    I found a dvd burner (8X) for my 600M on ebay.
    I had to do alot of research, because the drive originally sold with that model was +R only, and 4X. I found the newer models' drive would work.
    I started on Dell's accessories for my laptop's pages, and worked from there.
    Good Luck
    Feb 2004
    Australia
    Well , its usb1 port , not usb2 , best get an internal for it , and only burn to dvd while its connected to mains power .
    I only gave my external one dvd test so far , and it choked before it got started , but I'll give it another crack tomorrow when I get back from the farm .
    Well I though ... get off my butt and go get it from the other room now , and give it another go .
    Imgburn at 1x succesfully completed a dvd burn to my external lg unit on usb1 .
    Makes you wonder what all those others are saying that usb1 is too slow ... just watch the buffer go from full to 9% a heck of a lot ... dont do anything while that process is running .
    Maybe my unit is a freak ... the D610 that is ... who really knows .
    256mb ram / 1200mh cpu / 20gig hd / 32mb ati ... and now ... 13 tv out cables (the real dell part that works)
    I see them in ebay , I grab the whole lot .
