    Jul 2007
    Hey There,
    I have some content that I would like to convert to H.264 for playback on my iPhone, it is considered AVI Divx by ffmpegx right now. When I try to convert using any of the h.264 presets such as iPod h.264 320 or 640 or any of the other h.264 presets all I get when I convert is an output file that has a white screen and no content. I was attempting to use h.264 because of the relatively small file size and good image quality. Any help would be appreciated.
  2. Banned
    Jun 2007
    UNREACHABLE
    x264.exe
    Jul 2007
    I'm on a mac so an exe won't help. How would that help me?
  4. Banned
    Jun 2007
    UNREACHABLE
    Apologies. I hadn't paid sufficient attention to what you had actually written.
    x264.exe is just an apparently-decent CLI h264 encoder.
    But you are right, it's no use on a Macintosh.
    P.S.: BTW, the MP4s that iPhone is able to play back are
    100% MPEG4-compliant, or simply MPEG-4-derived?
    Jul 2007
    ok any ideas on what I should do then?
  6. Mod Neophyte redwudz's Avatar
    USA
    Since you are asking about Mac software, this would be better in our Mac Forum. Moving you.
  7. Member terryj's Avatar
    N35°25.24068, W097°34.204
    what software are you using on the mac to do this?
    iSquint? Visual Hub? or ffmpegx?
    Most of us use for mpeg-4 with h.264 encoding use
    Visual Hub, which seems to be better than ffmpegx
    as far as in terms of playback compatibility.
    "Everyone has to learn, so that they can one day teach."
    When I'm not here, Where can I be found?
    Urban Mac User
    Jul 2007
    I'm using ffmpegx, and thanks for moving this thread to the mac forum.
