So I'm trying to move Tivo recordings to a DVD (at least to try out and see how the it looks). I've moved the files to my computer, used DirectShowDump to remove DRM and was trying to edit in Movica but I had slight problems. At the start, for the first fraction of a second I'd have blocky green distortion, and at the end, the newly created .mpg would run a few seconds beyond where I had told it to cut (I did this twice to make sure I hadn't done it wrong). What could I do to fix this? Is there any other programs I could use, I'm really looking for the SIMPLEST editing possible here, just take off a touch at the beginning and end of episodes (it's an HBO show - no commercials). Also, would I be out of luck if i tried to use DVDFlick (never used it before) to burn the trimmed down .mpg's to DVD?
Results 1 to 11 of 11
Yes , tivo recordings are a pain , but you should beable to use mpeg streamclip to slice exactly what you want out ... very simple process .
Well I tried it out. It wouldn't work. Is there a reason why it is telling me to switch to the Quicktime alternative? I'd really prefer not to if I could - I just updated iTunes (with Quicktime) to 7.3.1 so I should be all good, no?
I still haven't found a solution to this. Are there any other programs that might work?
Thanks for responding. It took me a while to try Videoredo, but when I did, The beginning cut fine, but for no apparent reason, the last 8 or 9 minutes is just cut off. I tried this now on two different files and tried to do it more than once making sure my cuts were in the right place. Could I be doing something wrong in Videoredo? Or is it just another case of Tivo recordings being hard to trim?
Saving a clip (segment) as wmv in Movica
By anon_private in forum Newbie / General discussionsReplies: 19Last Post: 26th Oct 2010, 20:16 -
Saving Clips as wmv Files Using Movica Under Vista 32 bit
By anon_private in forum Off topicReplies: 0Last Post: 24th Oct 2010, 11:21 -
Movica splitting problem
By bartman99 in forum EditingReplies: 0Last Post: 11th Jul 2010, 21:33 -
Movica 6.6 beta - spyware? joining few wmv files & wants to contact Goo
By suzanne27 in forum Newbie / General discussionsReplies: 3Last Post: 28th Sep 2009, 17:15 -
ASFBIN and Movica : Batch File Joining Possible ?
By Alterego in forum EditingReplies: 0Last Post: 12th Oct 2007, 03:18
