    Nov 2005
    I am using SVCD2DVD 2.5.2850. I have noticed a really minor issue - definitely not high on the list of things to address.
    When restoring SVCD2DVD from a minimized state, it does not return the window to a maximized state as it was before minimizing.
  2. Member ChrissyBoy's Avatar
    Feb 2003
    Yorkshire!
    Yes i can replicate that - i will get it sorted - thanks.
  3. Member ChrissyBoy's Avatar
    Feb 2003
    Yorkshire!
    Thanks for the heads-up. I have fixed this in the latest build (2.5.3000) - can you confirm this is sorted?
    Aug 2007
    I am using the latest version of SVCD2DVD and I am experiencing a similar problem. In fact the program does not start in full screen and I have to expand manually. Further to this, if I run my cursor over the SVCD logo on the left of the top bar, or the icons at the left most without clicking, svcd will change size?
    Any suggestions please?
  5. Member ChrissyBoy's Avatar
    Feb 2003
    Yorkshire!
    Not sure what you mean - can you clarify? FYI: S2D will start non maximised (.i.e in a normal window state) BUT will remember the previous size of the last time.
