Here i go,
i have a avi movie file, where the audio is ahead of the video. that means its not in sync.
well, i tried my best to search in everywhere to solve this problem.
How can i use the delay in audio for about -383 ms, so that the audio and video will be in sync.
I am using K lite codec pack full version, which installed the media player classic on my pc.
when i checked on the AC3 filter and FFdshow filter, on both of the filter configuration i have found options where audio can be synced. but no matter how much i change on those filter settings, it doesn't apply to my movie. More over i have no clue while playing the movie with media player classic, which codec is actually being used for the audio. I have used the G sopt tool, but as i am a newbee i couldnt figure out what all those output from the Gspot really means.
Can some one please tell me how/which codec settings should i change? is any of the codec installed by the K lite is actually being used on the file or not?
i even converted the whole avi movie file into mpeg. and tried to sync the audio using Video Redo plus. this software fixed the sync problem for the first 20 minutes of the movie, then it gets out of sync again.
any help guys? Thanks in advance.
	http://yaai.sourceforge.net/
 Nicest tool for the job, but can be a little flaky.
 If you get an error loading your avi into it install >
 http://www.free-codecs.com/download/Koepi_XviD.htm
 or/as well as
 http://sourceforge.net/projects/ffdshow
  audio goes out of sync periodically with .avi movie on WMP11By JohnnyBob in forum Software PlayingReplies: 2Last Post: 3rd Sep 2010, 09:50
  Please Help... Audio and Video in movie (avi) get out of sync!!By dezerteagle323 in forum Newbie / General discussionsReplies: 2Last Post: 30th May 2010, 22:00
  How to fix audio sync mid movie?By 007craft in forum AudioReplies: 3Last Post: 8th Mar 2008, 12:55
  taking audio from one movie to sync in a movieBy bigdaddykane in forum AudioReplies: 9Last Post: 28th Dec 2007, 14:40
  audio stops way before end of converted movie and is out of syncBy jboyd in forum ffmpegX general discussionReplies: 11Last Post: 17th Dec 2007, 06:12
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
