Hi
I am trying to join 2 AVI XVID files together using virtual dub.The files use AC3 sound.After Joining the files,when i play the new AVI file where the join is ,i get a load click, then the sound after is low until i move the play slider to move the file on a bit,then the sound returns to normal level.I suspect there is a problem with the audio causing this.I searched and found someone else had the same problem and was advised to use AC3FIX to fix any problem with the AC3 audio and it worked for them.What i would like to know is the the step by step process to do this ie
extracting the audio
putting it through AC3FIX
Putting the hopefully fixed AC3 file back with the Avi file.
I have virtual dub and nandub and have install AC3FIX.
Any help explaining the process or any other solution will be gratefully received.![]()
Thank you
Hawklight
Results 1 to 1 of 1
Low Sound Output After Adding .ssa to .avi
By edlimym in forum SubtitleReplies: 4Last Post: 12th May 2010, 08:02 -
Join Avi (xvid) files together
By SpyJoe in forum EditingReplies: 11Last Post: 26th Aug 2009, 18:44 -
Convert AVI with H264 and AC3 to AVI with XVid and AC3
By ashwin.terminator in forum Video ConversionReplies: 4Last Post: 26th Jul 2009, 12:17 -
How to convert AVI/DivX/XviD with AC3 to DVD with AC3
By Baldrick in forum User guidesReplies: 52Last Post: 21st May 2008, 20:22 -
Make an xvid/avi from DVD but keep original ac3 surround sound?
By coolchris in forum Newbie / General discussionsReplies: 2Last Post: 26th Jan 2008, 08:35
