Hello I have an .avi file encoded using xvid codec (230mb) and I added an .ass subtitle and I need to convert this video w/ subs to .mp4/.mkv container using h.264/x.264 codec to have a smaller filesize but same quality. I was wondering how to convert a video file .avi (xvid) to .mp4 or .mkv container using h.264/x.264 codec... What programs should I use? Do you have any tutorial on how to do this?
Cheers!
--Tensai
what do you mean added?Originally Posted by Tensai
almost sounds like you've hardcoded the subs already. almost.
do you want to?
Anyway, you can't use ass subs with mp4.
If you want mp4, convert to srt and mux subs with mp4box(yamb).
If you want to keep the ass subs, you are going to have to go to mkv.
Encode with whatever and use mkvmerge of mkvtoolnix to mux.
The actual encoding can be done with many tools.
The easiest is probably Super to x264/mp4,
then mux that with your ass subs into an mkv.
You could also use megui, automkv, vfw x264...
(be sure to check program requirements)
If you have srt subs you can just load them into automkv.
Megui has muxer tools (the same one mentioned but they're in the pack).
You haven't said much about the source or your target size goals.
I suppose you are looking to encode to h264 with 'constant quality".
All simple tools. Try them, search for a specific guide once you settle on one.
Ask for help if you get stuck.
gl -
i was targeting to have a 100+mb video file size? is that possible? how do you set the desired file size to the tools you mentioned?
Lossless Conversion from AVI H.264 to MP4 H.264
By kenchen in forum Video ConversionReplies: 3Last Post: 22nd Oct 2010, 15:04 -
How to convert an h.264 MKV with softsubs to an h.264 MP4 with hardsubs.
By hawk16zz in forum User guidesReplies: 4Last Post: 27th Apr 2010, 12:41 -
MKV (h.264 file) conversion to AVI or MP4
By killwill169 in forum MacReplies: 43Last Post: 12th Aug 2009, 19:35 -
What is the best program to convert from H.264 mp4 to H.264 avi?
By Stealth3si in forum Video ConversionReplies: 6Last Post: 15th Sep 2007, 11:11 -
Having Problems converting h.264 mp4 to xvid using avisynth & vdubmod
By Rusty Shackleford in forum Video ConversionReplies: 3Last Post: 8th May 2007, 04:34
