Hello
I have a problem, can anybody help me?
I have a DVD-Video and I want to edit it in editing application (Edius) and then again I want to create new DVD-Video from it with new menu and subtitle.
Since my capture card has been damaged and right now I just have IEEE 1394, I think I can do it in two ways;
1- capture DVD-Video by IEEE 1394 as an AVI file and edit it in Edius and then export final video as a MPEG2 file and in the next stage take them to DVD authoring application and create DVD-Video with new menu and subtitle.
2- Importing Vob file directly to Edius(it support vob files) and edit it, then export final video as a MPEG2 file and then send them to DVD authoring application for creating new DVD-Video.
In your opinion which way is better? What would you do if you were me?
Quality and resolution are most important factor for me, I don’t want to lose any quality during these conversions.
Any advice would be greatly appreciated
sean
	You will lose a bit quality if you use edius because it reconverts the entire video clip. Some other editors like mpeg video wizard don't reconvert the entire clip but just the transitions, image resizing, image cropping and such that requires reconverting.Originally Posted by Sean_ve99
	Thanks for your reply, but someone professional editor told me to capture them as AVI because MPEG file isn't good source for editing.
 Are you going to tell me to choose second way?
	This guy is only giving you half the details. His advice only applies in certain situations.Originally Posted by Sean_ve99
 What kind of editing are you wanting to do, exactly?Want my help? Ask here! (not via PM!)
	I want to remove and add some part of video and change entire audio of video, I might use some filter like color correction (not so much) and after that I want to export it to Adobe Encore DVD for authoring.
	This way seems Ok but do you have DVD-Video player with IEEE 1394 output???Originally Posted by Sean_ve99
 If not, second option probably will give you better quality.
	What do you mean you have a dvd-video ? ... where ?Originally Posted by Sean_ve99
 If you talking about one of those dvd recorders , then that interface only works as input , not output .
 If it has a hard drive where it stores the recordings , there's only two methods you can use .
 Play it back , and while it dose so , record it to pc using a video capture device ... this gose for units refered to as tivo's as they encrypt the stored data .
 Or
 Rip the hard drive out , carefully , and use a tool like pvrexplorer to extract the clips to pc ... which might send warrantee south bound and down the drain .
  Best way to do basic editing to dvd video?By Sebastian2011 in forum EditingReplies: 15Last Post: 4th Apr 2012, 11:54
  Video Editing Software: mkv, h264 & DTS Editing?By techdls in forum EditingReplies: 8Last Post: 28th May 2011, 02:29
  Editing a DVD video in PremierBy smallears in forum MacReplies: 8Last Post: 9th Aug 2009, 13:55
  Editing video from a DVDBy BobAchgill in forum Newbie / General discussionsReplies: 10Last Post: 11th Dec 2008, 23:04
  How can I play this DVD-Video in editing application?By Sean_ve99 in forum DVD RippingReplies: 0Last Post: 9th Jul 2007, 17:56
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
 Quote Visit Homepage
				Visit Homepage
