    Dec 2006
    I got avis with multi ac3... commentary or aux languages .. problem is they all play at the same time, and i got the same amount of ffdshow icons in tray as audio streams :C (same in wmp9 as in Powdvd 5)
    whats wrong?
    I remember in my past windows install:P i could select what audio i wanted to play right in Powerdvd (i think it was) menus, now i have an icon for it but i cant press it.
    Also what happens when i convertxtodvd this to my dvd player? will audio select just work?
    have little hope this will be solved. help anyway
    USA
    You could drop them into VirtualDub after adding the AC3 ACM Decompressor and remove or save out the channels you want. ConvertX may be able to let you select the channel you want, but I don't know how many channels it can handle. Give it a try. This is assuming all the channels are separate.
    Try VLC Media Player for playback. It does a good job with handling multiple channels.
    There are likely other ways and programs that will work also.
    And welcome to our forums.
    Dec 2006
    thx
