  1. Member thecrock's Avatar
    May 2005
    england
    I I don't know where to post this so..here goes.
    My dvdwriter has stopped working. I open the draw and it snaps straight back shut again. It won't burn any dvd's just say to insert a blank dvd. The dvd's are blank.
    My writer is ATAPI
    Anybody?
    “He who makes a beast of himself gets rid of the pain of being a man.”
    Feb 2004
    Australia
    May simply be at the end of its service life , usual sign of draw snapping shut , but try
    Replacing the ide cable (or simply remove and reinstall cable)
    Swap different power connector .
    Try either disabling or enabling the "autorun" feature on the drive and see if it makes a difference ... windows can be fickle when it comes to "refresh" of contents .
    If you had a bootable linux which supports cd/dvd burning , you could run a test burn under linux ... if it works , then you'd have a windows os problem .
    These are not so easy to repair without a lot of system info given to determine the fault with software , and most go the reinstall os routine .
    Most come in the form of non-friendly burning programs , such as roxio and nero dont like each other , which is a right mess . Should you find yourself with multiple programs , each capable of burning to media , then you need to reasses your requirements in order to prevent further , and future conflicts from re-appearing .
    Media could also cause issues with older drives , which comes down to upgrading the drives firmware as a last resort ... if that fails , just get a new drive ... one from lg .
  3. Member thecrock's Avatar
    May 2005
    england
    Thanks Bjs I think I will just replace the unit.
    Peace.
