I've been using K-Lite codec std pack for the last few yrs with maybe 2 or 3 restarts per month, however lately it's almost an daily affair and I'm 100% sure it's due to the newer K-Lite/MPC.
From Google, I found zero codec pack http://impulse7.com/zero/ and now I've:
1)ffdshow 1349 by XXL
2)AC3 filter 1.45b
3)MPC HomeCinema V1.8.8.0 http://sourceforge.net/project/showfiles.php?group_id=170561
4)Real Alternative Lite 1.52
No restarts/errors from MPC for the past two days and I COULD play all my video files INCLUDING 99% of .mov files except these two .mov files:
1)no sound and no picture
V:\To Delete\Ric.mov::Output
QuickTime Movie Parser::audio 0
Media Type 0:
Audio: 0x4d57 44100Hz stereo 1411Kbps
AM_MEDIA_TYPE:
majortype: MEDIATYPE_Audio {73647561-0000-0010-8000-00AA00389B71}
subtype: Unknown GUID Name {00004D57-0000-0010-8000-00AA00389B71}
formattype: FORMAT_WaveFormatEx {05589F81-C356-11CE-BF01-00AA0055595A}
bFixedSizeSamples: 1
bTemporalCompression: 0
lSampleSize: 4
cbFormat: 18
WAVEFORMATEX:
wFormatTag: 0x4d57
nChannels: 2
nSamplesPerSec: 44100
nAvgBytesPerSec: 176400
nBlockAlign: 4
wBitsPerSample: 16
cbSize: 0 (extra bytes)
pbFormat:
0000: 57 4d 02 00 44 ac 00 00 10 b1 02 00 04 00 10 00 WM..D¬...±......
0010: 00 00 ..
and
2) no picture BUT got sound
U:\BM ELS FM\FM - Home.mov::Apple Video Media Handler
Media Type 0:
Video: SVQ3 320x240
AM_MEDIA_TYPE:
majortype: MEDIATYPE_Video {73646976-0000-0010-8000-00AA00389B71}
subtype: Unknown GUID Name {33515653-0000-0010-8000-00AA00389B71}
formattype: FORMAT_VideoInfo {05589F80-C356-11CE-BF01-00AA0055595A}
lSampleSize: 1
cbFormat: 88
VIDEOINFOHEADER:
rcSource: (0,0)-(0,0)
rcTarget: (0,0)-(0,0)
dwBitRate: 0
dwBitErrorRate: 0
AvgTimePerFrame: 0
BITMAPINFOHEADER:
biSize: 40
biWidth: 320
biHeight: 240
biPlanes: 0
biBitCount: 0
biCompression: SVQ3
biSizeImage: 0
biXPelsPerMeter: 0
biYPelsPerMeter: 0
biClrUsed: 0
biClrImportant: 0
pbFormat:
0000: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................
0010: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................
0020: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................
0030: 28 00 00 00 40 01 00 00 f0 00 00 00 00 00 00 00 (...@...ð.......
0040: 53 56 51 33 00 00 00 00 00 00 00 00 00 00 00 00 SVQ3............
0050: 00 00 00 00 00 00 00 00 ........
Media Type 1:
Video: SVQ3 320x240
AM_MEDIA_TYPE:
subtype: Unknown GUID Name {33717673-0000-0010-8000-00AA00389B71}
lSampleSize: 1
cbFormat: 88
VIDEOINFOHEADER:
dwBitRate: 0
dwBitErrorRate: 0
AvgTimePerFrame: 0
BITMAPINFOHEADER:
biSize: 40
biWidth: 320
biHeight: 240
biPlanes: 0
biBitCount: 0
biCompression: svq3
biSizeImage: 0
biXPelsPerMeter: 0
biYPelsPerMeter: 0
biClrUsed: 0
biClrImportant: 0
pbFormat:
0040: 73 76 71 33 00 00 00 00 00 00 00 00 00 00 00 00 svq3............
I know if I'm to install QT Alternative(or the new QT Lite), I could play these two files using MPC, however I'm NO fan of anything from Apple and also since I can currently play 99% of .mov files just using the defaults ffdshow without installing QT Alternative(or the new QT Lite)...can any video/codec guru out here help me, maybe something I need to adjust/enable in ffshow/AC3 filter or?
Thanks in advance.
I noticed this on the 'zero' page as a reason to use their pack instead:
another codec pack destroyed your system?That's too often the result of installing a indiscriminate codec pack like K-lite.
Quicktime Alternative is definitely not from Apple.I think they are not happy that others have used their codecs. I would just install it. Even with QTA installed there's is no guarantee you can play those files. They may have other problems.
Thanks redwudz for the feedback.
I could play the above two .mov files after installing QT ALT/QT Lite (I already tested!)
What'sme is how come only these two .mov files? as the rest of my .mov could be played without the need of QT ALT/QT Lite
P/s QT ALT is dead after 1.81 (QuickTime components version 7.1.6.200) and the replacement is QT Lite 1.1.0 (QuickTime components version 7.2.0.240). -
Sorry, I know very little about Quicktime and the .mov format.
I suspect there are many variations to the format, much like MPEG-4. Someone that knows more about them might be able to give a better answer.
Thanks again redwudz and jagabo.
Well MediaInfo is excellent (at least for me), as it provides straight forward answers! (I could never figure out how to use GSpot, as it always provides too much/too little or "???/maybe" whenever I tried to check file info).
OK, for my two .mov files (from MediaInfo):
1)WMV3/ADPCM
2)Sorenson3/MPEG-1/2 L3
so, how can I play these two files using ffdshow? or do I need MORE codecs?
Thanks again.
p/s I already tried enabling all to "Libavcodec" under codecs (ffdshow), but still no go
Which codecs to play .vob files?
By chewie8008 in forum Software PlayingReplies: 21Last Post: 8th Dec 2013, 16:18 -
Basic advice on codecs/filters/hardware combinations
By mrg155 in forum Newbie / General discussionsReplies: 5Last Post: 19th Dec 2011, 10:37 -
AVI files with Divx codecs - will they play?
By pooksahib in forum Video ConversionReplies: 7Last Post: 29th Jan 2011, 15:59 -
Need advice on playing blu ray isos
By dafoe in forum Media Center PC / MediaCentersReplies: 7Last Post: 28th Nov 2010, 22:53 -
No Video with MKV files advice on playing on a PS3
By edmond in forum Newbie / General discussionsReplies: 6Last Post: 28th Jul 2008, 04:42
