I really want to reformat my hard drive with my recovery disk but since my DVD drive is broken I can't do so. My problem is I have to many codecs sitting on my computer and I really think it's affecting my computer's ability to properly convert videos. Is there anyway to wipe out all the codecs on your computer and start over? When I downloaded Zoom player it "disconnected" many of the codecs (all?) but they're still out there. I really want to wipe them out and start over.
thanks
Try Codec Sniper. It should be able to remove most of them. And whatever you do, don't install a codec pack.
It will commonly lead to the same problem you have.
thanks, i got rid of two broken codecs. I still have 177 though and I'm sure that's too many. I'm afraid of eliminating all of them though because I read about how dangerous that could be.
Does anyone know how to install only the codecs that came w/ your computer when you bought it? -
There's this page from MS on installed codecs for XP: http://support.microsoft.com/kb/899113
filmedit is also worth a look. Trickier to work with than CodecSniper, but does a better job.
Read my blog here.
Starting Point
By NeptuneDrew in forum Video ConversionReplies: 10Last Post: 19th Jan 2011, 14:40 -
Help D; Codec Sniper Entries/Registering Codecs/Broken Codecs
By Antischism in forum ComputerReplies: 0Last Post: 5th Nov 2008, 14:29 -
Starting out, maybe venting or both
By Oldone in forum Newbie / General discussionsReplies: 2Last Post: 15th Sep 2008, 18:38 -
Please explain codecs to me: codecs within codecs?
By idsane in forum AudioReplies: 5Last Post: 2nd Sep 2008, 14:39 -
Vista Codecs - New PC Requirements - Are Codecs Needed
By doggyofone in forum Newbie / General discussionsReplies: 6Last Post: 30th Aug 2007, 19:52
